Steady oil leak help
Old Feb 2, 2012 | 07:00 AM
78f3504x4's Avatar
78f3504x4
I just changed my oil in my '95 PSD, and started her back up. I checked underneath for leaks, and I saw a steady stream of fresh oil coming from the (HPOP?), not sure if thats what it is. Its on the left side of the engine right near the oil filter. Is this a major job? It slowed down to a trickle after a minute. I'll try to post up a pic. Any help would be great. Thanks.
Old Feb 2, 2012 | 07:07 AM
fordpride's Avatar
fordpride
Sounds like the oil cooler
Old Feb 2, 2012 | 07:16 AM
PowerstrokeRyan's Avatar
PowerstrokeRyan
If you get a chance to look at it and its undeath the valve cover then its your oil cooler just did a rebuild thread on it about two weeks ago. "Oil cooler rebuild" its a $63 kit at riffraff. Its not hard to do just time consuming.
Old Feb 2, 2012 | 08:55 AM
78f3504x4's Avatar
78f3504x4
Any idea how much a new one is? I looked up Autozone but it wasen't much help. I'd rather replace than rebuild
Old Feb 2, 2012 | 09:34 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
Unless the oil cooler its in very bad condition I wouldnt replace it just a rebuild, but here are some part numbers for you
Oil Cooler (no gaskets included)
(International) 1815904C1
Oil Cooler Housing Gasket (front)
(Ford) F7TZ-6A636-AAA
(International) 1831666C1
Oil Cooler Header Gasket (rear; oil filter end)
(Ford) F4TZ-6A636-AA (97-up)
(Ford) F4TZ-6A636-B (96-before)
(International) 1831665C1
Oil Cooler O-Rings (one each to seal cooler at each header)
(Ford) E3TZ-6C610-A
(Ford) E4TZ-6K649-E
(International) 1807563C1, Inner 1804414C1 Outer
I dont know about prices, ask to Riffraff diesel performance
Old Feb 2, 2012 | 10:06 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Here you go.
Riffraff Diesel: Oil Cooler Rebuild Kit
Old Feb 2, 2012 | 10:16 PM
oldbird1965's Avatar
oldbird1965
$210 from PartsGuyEd.com. 1c3z-6a642-aa 8772477904
Tdracer344
Dec 21, 2016 11:18 PM
Mattruck1992
Nov 20, 2011 09:07 PM
YoungFordAddict66
22
Jan 12, 2011 07:42 PM
BOBSDIESEL
Sep 14, 2005 02:28 PM
DarylZ
Dec 3, 2004 02:36 PM
