upfitter switches
Old Feb 2, 2012 | 06:36 AM
Jordan532's Avatar
Jordan532
upfitter switches
Hey guys i wanted to put sum fog lites on my 11 sd...has ne one wired into them switches?.... i do believed they are fused but where do u tap into them?... thanks
Old Feb 2, 2012 | 08:19 AM
BrockwayMT's Avatar
BrockwayMT
Upfitter wires are under the steering wheel behind the kick plate. There should also be some blunt end pass through wires going to the engine compartment so you don't have to drill through the firewall.
Look in the Body Builders Layout Book at fleet.ford.com
Old Feb 2, 2012 | 12:23 PM
bookem15's Avatar
bookem15
if you look right above the ebrake you will see 4 wires taped to the wire harness but I forget the colors of the wires but they are labeled aux 1-4 and yes they are fused. here is the link to the colors and size of fuses.
https://www.ford-trucks.com/forums/a...0&d=1309099968
CO Wapiti
Jul 21, 2025 10:12 AM
ctoddrun
Jan 13, 2019 08:19 PM
murraydav
May 23, 2013 02:23 PM
llllllllll
May 18, 2010 06:05 PM
T.Mainus
Feb 21, 2010 10:20 PM
