rear leaf problems..
Old Feb 1, 2012 | 11:40 PM
fordcaver91's Avatar
fordcaver91
ok i got a 89 ford f150.. i was workn on pullin the leafs because they were cracked.. well i got everything off except the front bolt.. theyre stuck n dont even move.. any suggestions?? thank yall..
Old Feb 1, 2012 | 11:44 PM
Midnite1987's Avatar
Midnite1987
Bigger snipe lol, they will come off might need alot of penetrating fluid or some heat
Old Feb 2, 2012 | 11:36 AM
jokerforever's Avatar
jokerforever
Heat, penetrating oil, and a very big breaker bar. With enough of those three it will come loose or break. Either way you can remove the spring.
If you don't have enough of those three you will have to cut the bolt off. A sawzall, grinder or hot wrench should do the trick. Bolts are cheap. Don't worry too much about saving it.
Old Feb 2, 2012 | 11:57 AM
OverReved's Avatar
OverReved
Since you are going to get new springs, a new set of bolts won't add that much more to the job. It's a good idea anyway.
Old Feb 2, 2012 | 12:09 PM
kd0axs's Avatar
kd0axs
Just cut it and be done with it. You'll spend all day heating it and accomplish nothing but melting the rubber bushing. Been there done that.
Old Feb 2, 2012 | 04:45 PM
fordcaver91
well ive soaked it wit just bout everythang and used a big freakn breaker bar + cheater pipe and it only moves a little.. just did it ta my ranger last rear and it just came right out.. wth??
Old Feb 2, 2012 | 04:51 PM
jokerforever
Pull out the hot wrench---it's cuttin' time
or play with it for a couple more days. Rust is a "female dog"
Old Feb 2, 2012 | 09:53 PM
fordcaver91
may sound stupid but wat is a hot wrench?? a grinder or somethan??
Old Feb 2, 2012 | 09:59 PM
Midnite1987
i believe they mean cutting torch but i could be wrong too.
Old Feb 2, 2012 | 10:18 PM
critterf1's Avatar
critterf1
Cutting torch. I call them a "blue wrench".
Old Feb 3, 2012 | 12:31 AM
jokerforever
Yep, that's what I mean; oxy acetylene. Like these guys
Okay, so everybody doesn't have a cutting rig at the house. I was being a little tongue in cheek there. Really, if you can't get these bolts out then you're going to have to cut them. Use whatever cutting tool you have. I would just use the cutting torch because it's faster. But you do have the possibility of setting the truck, or yourself, on fire.
freakdaddy
Jul 30, 2009 02:47 AM
Ken2600
Jul 21, 2008 10:27 AM
Katmandu
Nov 26, 2005 03:27 PM
Villagemonkey
Nov 6, 2004 08:22 PM
orangeford
Oct 11, 2004 11:09 PM
