Sponsored by: Real Truck
timer relay/light switch/remote door locks
Old Apr 25, 2003 | 02:58 PM
cwb's Avatar
cwb
How can you not have wd-40?How?How? I have left home without my wallet but never without my wd-40.
Old Apr 25, 2003 | 04:37 PM
nafzimo's Avatar
nafzimo
Ok Haroutd, I can understand WD40 for sex... but how do you use it for food and shelter?
I just got back from the Dr. He prescribed "Accuretic" for my high blood pressure. And the voices and twitches... they ain't new.
Matt
Old Apr 28, 2003 | 02:43 AM
ColtM4's Avatar
ColtM4
WD-40 didn't work. gonna have to pull some relays and switch them around to see if that changes anything. I don't have WD-40 because I use all different kinds of lubricants or water displacements because WD-40 and guns don't mix too well (no corrosion inhibitors/cleansers)
Old Apr 28, 2003 | 07:28 AM
haroutd's Avatar
haroutd
From: I'm lost somewhere in NJ -- can someone please find me?!?!?!?
You should have said so earlier -- RemOil would have worked, too. Sorry the simple thing didn't work out, and good luck with the troubleshooting.
Old Apr 28, 2003 | 10:22 PM
Mwachel's Avatar
Mwachel
If this all started happening after you had the radio put in then I would be at the installers door bright and early telling him to fix it. If they refuse to fix it or can't then I would have Ford do it and present the bill to the installer. Small claims court after that. They messed up your wiring somehow or shorted out something.
Now, if it was happening before the install then disregard!
Im not too uptight am I?
Good luck.
Old Apr 29, 2003 | 09:48 AM
99sdpstd's Avatar
99sdpstd
[but how do you use it for food and shelter?
It masks the taste of my wifes cookin and it repells water and mosquitos.
you gotta try unplugging that radio. Last in - first out. If it was fine before it should be fine after unplugging it.
Just my $.02
Old Apr 29, 2003 | 11:26 AM
nafzimo's Avatar
nafzimo
Originally posted by 99sdpstd
...you gotta try unplugging that radio. Last in - first out. If it was fine before it should be fine after unplugging it...
Only if you assume the two events are connected. A door switch could fail at anytime, no matter what you do with the radio.
Matt
Old Apr 30, 2003 | 03:18 AM
ColtM4's Avatar
ColtM4
My problem with the door switch/timer relay fixed itself for about 1/2 mile and as soon as I shut her down it went bad again. Now I'm frustrated...
PS Is it difficult to replace the door sensor switch? They don't seem to be very expensive and wondering if they are hard to get into and replace. It looks like the handle is riveted in on my supercab doors.
