have a quick question fer ya will an front seat out of a 1990 ford bronco bolt into my 1986 ford f150 and thank you for your help on the other question and thank you on this one also
Bench to bench? They should, just use the tracks from the donor seat. Buckets should also swap but I don't know about the inside bolts. The outside ones should line up and at worse you have to drill for inner bolts.
I put buckets from I think an '85 into my '81 that came with a factory bench seat. Outer holes lined up fine but I had to drill the inner holes.
You will need to get some flat washers so you can level the seats, I know the driver side seat was sitting at an angle when I was test fitting everything. I accidentally forgot to align the tracks though and it worked out in such a way that they were offset just right so that the seat sits level. Passenger seat sits level on its own.
