Brown Coolant
Old Jan 31, 2012 | 06:53 AM
BlackNGoldRules's Avatar
BlackNGoldRules
Brown Coolant
Just checked my coolant level in my radiator and noticed I have a milky brown substance on top. When I see this, the first thing I worry about obviously is a blown head gasket or some kind of leak letting oil in. Well, I checked the oil and it looks perfectly fine. It's not foamy or anything. The truck runs just fine too. No large amounts of white smoke coming out. The second thing I think of is maybe the tranny fluid is leaking in through the cooler in the radiator. Well, I checked the tranny fluid, and it looks fine as. Looks like it should. Could one of those still be leaking into my coolant without the coolant leaking back into the oil or tranny fluid? Looking at the brown substance, it just has the look to me of some kind of oil just the way it floats to the top. Doesn't just look like dirty coolant to me. Anyway, any advice on this would be appreciated. Thanks.
Old Jan 31, 2012 | 05:43 PM
Phinxter's Avatar
Phinxter
well if you got a crack in a head oil pressure is higher than the coolant so it can seep into a coolant passage. What engine you got?
Old Jan 31, 2012 | 10:29 PM
BlackNGoldRules
Hmmmm. My engine is supposed to be popping up in my signature. Anyway, here it is, thanks.
2000 Ford Ranger XLT Supercab 2WD 3.0L Flex Fuel V6 182ci
Old Feb 1, 2012 | 12:06 PM
Blue Eyed Cyclops's Avatar
Blue Eyed Cyclops
^^^ X2, could also be a break in the head gasket between an oil passage and a coolant passage.
Old Feb 1, 2012 | 12:07 PM
ford390gashog's Avatar
ford390gashog
Did you buy the truck new? OR did you just buy it?
Old Feb 1, 2012 | 04:00 PM
Phinxter's Avatar
Phinxter
Yes thats also true and for a 3.0 more likely than a cracked head.
Old Feb 1, 2012 | 09:21 PM
BlackNGoldRules
It was a year old when I bought it so I've had it almost 11 years now. It has almost 163,000 miles on it now. One thing I noticed a couple of weeks ago was that the tranny fluid got really low and I had to refill it. It took almost a quart. Usually, the tranny fluid would never move. It hasn't moved since I filled it back up, but once I discovered this I wondered about that leaking into the radiator through the cooler. No coolant in the tranny fluid that I can notice though. Anyway, just something else I'm throwing out there that I noticed recently. I'll get it to a mechanic and see what they say.
Old Feb 2, 2012 | 10:09 AM
wtroger's Avatar
wtroger
You just answered your own question. could very easily be tranny fluid getting into the rad via the tranny cooler. You really hope it is only going that direction the other way and it will ruin the tranny
Old Feb 2, 2012 | 03:42 PM
Phinxter's Avatar
Phinxter
Yeah if coolant gets in the tranny it's toast, every rubber seal and anything with friction material has to be replaced.
Old Feb 4, 2012 | 03:12 PM
mebe2k's Avatar
mebe2k
after reading this thread..now i've got some ideas why i'm finding the same type of stuff in the coolant on my 88..i wonder if one of the heads is cracked..2.9L engine..also the cooling system would over pressurize.. but now that problem went away..
Old Feb 11, 2012 | 01:34 PM
BlackNGoldRules
Just to update, I found out that I do have a leak in the tranny cooler inside the radiator. Now, I have two options. Either, replace the radiator, which I have done once before. Or, install a separate tranny cooler and just close up the holes left from the tranny cooler on the radiator. Now, if I go the route of installing a tranny cooler, how difficult a job is this? Will I have to get new lines or can I somehow use the current lines for it? I'm guessing I would have to install it in front of the radiator so it gets air flow. Anyway, any advice on this would be appreciated. Thanks.
Old Feb 11, 2012 | 03:15 PM
03 Maz B23's Avatar
03 Maz B23
If you went the aux cooler route it should have flex tubing/couplers to attach to your existing fittings at the radiator. One thought for consideration might be that the tranny fluid depends on some of that residual heat from the coolant to keep the fluid at proper temp in the winter months. Based on where you live that could be an issue.
Old Feb 11, 2012 | 05:15 PM
Phinxter's Avatar
Phinxter
I would go with a new rad just because of what 03 MAZ B23 said and if the rad is original it prolly has some corrosion inside unless it has been ridiculously maintained. My Plymouth was flushed every 2 years since new by me and it still got scale built up inside and the fins rotted away over time. I replaced it with a aluminum rad, much better. I think an external cooler is meant more as an aux cooler to use in conjunction with the stock cooler.
Old Feb 12, 2012 | 10:01 AM
jim collins's Avatar
jim collins
Sounds like the radiator is about gone,i would replace it before it blows out in the middle of no where. As far as trany coolers they can be used alone if they are sized right and placed in a good air flow . I use them alone a lot and have never had any problems. I never did like the idea of water and trany fluid being that close together.
Old Feb 13, 2012 | 09:12 AM
KhanTyranitar's Avatar
KhanTyranitar
To be honest if your tranny cooler inside the trans is leaking you need to replace the radiator anyway. Installing a separate cooler is a good idea too, your trans can always use all the cooling it can get. If you bypass the stock trans cooler, your radiator is still leaking, in fact it may leak more if the cooler isn't hooked up to anything.
If you run a separate trans cooler, its a good idea to leave the stock one in place anyway. The stock one, even if its small, is very efficient, oil to water is a fairly efficient heat exchange. It also helps the trans get to operating temperature more quickly. The proper way to hook it up is to come off the return line of the stock cooler, run it to your new cooler, then connect the return on the new cooler to the line back to the trans.
You need to focus on your known existing problem. Good radiators are important, and I've found too many parts store radiators are of marginal quality, and do not provide that great of cooling. They get by, thats about it. Finding the good ones is sometimes tricky. A brand I do recommend, that is not available at most parts stores, is Performance Radiator. They have better cooling performance, often with slightly thicker cores, more fins, and more thermally conductive materials. Focus on brands that have better warranties, and that explain why they are better.
