Sponsored by: Real Truck
Hubs
Old Jan 31, 2012 | 03:00 PM
VONxRUBENxLA's Avatar
VONxRUBENxLA
Ok here we go
So no switch for the hub but I bet the manual.
So can I just lock them and by twisting it?? There in auto right now.
Old Jan 31, 2012 | 03:02 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Originally Posted by VONxRUBENxLA
Ok here we go
When you turn the 4x4 ****, the hubs *SHOULD* automatically lock. If they dont, you can get out and lock the hubs manually. Its a fail safe.
Old Jan 31, 2012 | 03:05 PM
VONxRUBENxLA
I'm soo confused with all this lol. So since most of my driving it around town should I leave it on auto??
Old Jan 31, 2012 | 03:13 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Leave it on AUTO all the time no matter where you are. When you go off road, and you need 4x4, just flip the switch in the dash. This will lock your front wheels. If it doesnt (you will know because you will still be stuck) get out and manually lock them. Then when you get home, unlock them and fix the reason they didnt lock. You should never need to put it into LOCK unless something fails.
Old Jan 31, 2012 | 03:20 PM
AllaboutMPG's Avatar
AllaboutMPG
Yes, by leaving the hubs in auto(as long as they are working correctly) the front wheels are not locked to the axle. When you select 4x4 the transfer case is activated and the hubs lock automatically. What happens often with these systems is that
1. you develop a vacuum leak and when you select 4x4 the transfer case engages but the vacuum doesn't reach the hubs and they don't lock or
2. the hubs get cruddy on the inside and when you take it out of 4x4 they don't disengage. This means you are running around in 2wd but because the hub or hubs are still locked you are now spinning the front axles and eating up MPG and creating unwanted wear and tear on the front axle. As long as your vacuum lines are in good condition and your hubs are maintaned the system should work fine.
If you have a vacuum leak you can always get out and set them to lock before you need them.
I went to manual hubs because when I got my truck the plastic on the outside of the factory hubs was cracked and allowing water and debris in so they would stick even if I cleand them often. I want to know that when I don't want it in 4x4 the front axle is not turning.
Fortworthian
Feb 17, 2018 09:49 PM
dell
May 28, 2007 08:29 PM
Flywest
Jan 30, 2007 07:38 AM
superpony18
Mar 16, 2006 11:34 PM
schapman
Offroad & 4x4
17
Nov 15, 2003 09:21 PM
