COOLANT LEAKS
Old Jan 30, 2012 | 09:03 PM
marine57_4's Avatar
marine57_4
Unhappy COOLANT LEAKS
i first smelled coolant after driving the 2011 f-350 kr dually pickup. than the next day i noticed about a 3" diameter spot on the garage floor. it was coming down from the front and just off center towards the driver's side of the engine. anyone having any coolant leak problems?
Old Jan 30, 2012 | 11:57 PM
summet20's Avatar
summet20
Yep had the exact same problem with my truck at 45,000 miles. Had a small pin hole in the radiator more towards the driver side . I think this will be an issue with alot of these trucks its just a matter of time. Warranty covered mine and it was replaced. I also pointed it out to some other guys that have new trucks and they also found out theirs were leaking too after inspection. The 6.4L also had similar issues.
Old Jan 31, 2012 | 12:28 AM
ruschejj's Avatar
ruschejj
I had a new radiator at 59,000 miles. Including the five I had replaced in my '08 6.4 this made 6 radiators in the last 4-5 years.
I dunno what it is about me but I think I have the award for most radiators......
Old Jan 31, 2012 | 12:41 AM
PrinceValium's Avatar
PrinceValium
that's bad!!
Old Jan 31, 2012 | 06:43 AM
ruschejj's Avatar
ruschejj
I know, it's crazy. Friends in the 6.4 forum might have one or two go out, most have zero issues. It is strange. Only thing I do is two things, I drive a lot and I tow at least 6,000 pounds of trailer all the time. I don't get crazy heavy and I'm certainly not the only one that works my truck like this.
I never had an engine problem from the 6.4 or the 6.7 though. Main reason I got the new motor was this cooling system issue and the 6 speed trans. Funny how things go.
Old Jan 31, 2012 | 09:41 AM
darren32's Avatar
darren32
I had a leaky water pump replaced under warranty at about 30,000 kM.
Is this where it is leaking from?
If so it is water pump.
There are at least a few here that have had leaky water pumps.
Thanks
Old Jan 31, 2012 | 04:36 PM
Andrew010's Avatar
Andrew010
Hey Darren, did you take your truck in for the water pump with the tuner/exhaust on?
Old Jan 31, 2012 | 04:40 PM
darren32's Avatar
darren32
Yes sir (but they already know it was tuned).
I LOVED driving into the "drive in" service area. Gave her a little blast before I shut it down and a few people hit the deck
Old Jan 31, 2012 | 04:43 PM
Andrew010's Avatar
Andrew010
Did warranty still cover the water pump repair?
Sorry for the thread hijack....now back to your regularly scheduled programming.
Old Jan 31, 2012 | 04:45 PM
darren32's Avatar
darren32
Yes they covered it under warranty.
Thanks
Old Jan 31, 2012 | 04:59 PM
senix's Avatar
senix
radiator queen
Sorry, could not help myself
Now back to the regularly scheduled programming
Old Jan 31, 2012 | 07:43 PM
ruschejj's Avatar
ruschejj
I did not intend to hijack, should be noted that the water pump leak is a real possibility. I'm habitually thrown into leaky radiator hysteria.........
Apologies. First round is on me.
Old Jan 31, 2012 | 09:02 PM
flyinnuts's Avatar
flyinnuts
Marine,
Had my radiator replaced at 23k. Puddle on the floor was coming from drivers side very front of the frame.
Replaced under warranty.
Old Jan 31, 2012 | 09:51 PM
marine57_4's Avatar
marine57_4
COOLANT LEAKS
thanks guys,
i will go to the ford dealer and let them figure it out and take care of it. i am going on 1&1/2 years with my 6.7 and 20k+ miles.
Old Jan 31, 2012 | 09:54 PM
marine57_4's Avatar
marine57_4
hey darren32,
how did you get your dealer to warranty your 6.7 with the mods?
also what kind of milage and performance are you getting?
