Just check to see if there is a counterweight behind the balancer. If so then the 360/390 flywheel won't work.
If no counterweight then you can use the 360/390 flywheel and clutch (or even the 400 I think) and then use the 400 bellhousing on the 460.
the 390 is internally ballanced 410 and 428 (in the FE famialy) are to the best of my knowledge the only externally ballanced engines
