Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Allison transmission help
Old Jan 30, 2012 | 07:41 PM
mudslinger2's Avatar
mudslinger2
Hello all,
I am looking to update my 1968 ford c 950 it has the original 534 boat anchor with 16000 miles but runs like new. I would like to remove the fuller 5 speed and replace with an allison auto. Back in the day they used an allison mt 42 but i was wondering if there is something more modern without any electronics i could use. Also what bellhousing to use not sure how to mate them up I think i have a SAE #2 bell housing but not sure any help would be greatly appreciated.
Mudslinger2
Old Feb 1, 2012 | 12:34 AM
dmanlyr's Avatar
dmanlyr
Hello, yes you are correct, back in the day the Allison of choice (up until 1972) was the MT42 6 speed behind the 401-477-534 engines.
Later versions used either the MT640 (4 speed) series or the MT650 (5 speed) series. There are several sub groups in each - for example there is a MT641, MT642, MT653 and so on.
Do not get sucked into a AT540 series, they are a lighter duty trans not really suited for heavy hauling. (they are ok if you stay within Allisons max GCWR ratings though, which I can guarentee you is less than the GCWR on your truck with a stock 534)
Probably the best bet is look for a entire donor truck for the entire setup as trying to piece this all together from various sources can be fustrating and expensive.
Things to think about - do you need a PTO? Not all newer Allisons have that provision. Parking brake on the rear of the tranny? Is your rear axle a single or two speed? Is your existing manual a OD 5th or 1:1 5th? The Allisons that we are taking about here are 1:1 top gear.
Since you have a 1968, It might be easier to get a MT42 setup as on the older trucks it would be more of a bolt in thing... And since the entire MT30-31-40-41-42 series are now considered obsolete (although Allison still offers rebuilds) it can be a lot cheaper than the later MT 600 series. Heavy truck parts net it seems has quite a bit of this older stuff, although I cannot vouch for its condition.
Food for thought
David
Old Feb 1, 2012 | 07:27 PM
mudslinger2
Thanks for the great info , i have been looking for a donor but here in the northeast there is not much left of the old stuff. Also been looking at a bus with DD and allison, thanks again.
Mudslinger2
HT32BSX115
19
Feb 12, 2023 07:06 PM
52-F2
Nov 25, 2012 06:46 AM
Adamsbugs
Oct 24, 2011 07:59 PM
lilreddevilF-100
Jun 28, 2011 10:38 PM
BBF250
Jun 21, 2006 10:55 PM
