brake problem
Old Jan 30, 2012 | 11:29 AM
F-350Beast's Avatar
F-350Beast
brake problem
I just changed out the rotors on my 90 f350 4x4. and now about a week later i noticed it is pulling to the right when i hit the brakes. so today i jacked it up and noticed the right wheel feels like the caliper wont retract as much making it hard to turn the wheel over. i replaced this caliper about 2 years ago b/c it did the same thing. could it be a bad caliper or is there something else that might be going on that's causing this?
Thanks.
Old Jan 30, 2012 | 11:44 AM
tjc transport's Avatar
tjc transport
i ain't rite
quality of rebuilt parts has gone in the crapper over the past 10 years.
it is very possible that your 2 year old caliper is bad again.
Old Jan 30, 2012 | 11:47 AM
F-350Beast's Avatar
F-350Beast
yeah that's what im thinking too. im gonna see if its still under warranty and just replace it. thanks for your help.
Old Jan 30, 2012 | 12:04 PM
IDIDieselJohn's Avatar
IDIDieselJohn
When you replaced your caliper, did you flush out the entire brake system?
20+ year old brake fluid can cause problems in brand new parts as well.
But yes, rebuild quality doesn't really exist anymore.
Old Jan 30, 2012 | 12:29 PM
Phy's Avatar
Phy
Another possibility is a bad flex hose at that wheel. I've not had it myself, but I've read about several people who had a collapsed flex hose that wouldn't release pressure from the caliper... You can find this if you get the problem to happen, and loosen the hose at the caliper. If the hose is the problem, the caliper will release...
Old Jan 31, 2012 | 11:23 AM
F-350Beast's Avatar
F-350Beast
yep turns out it was the caliper. dont know what caused it to fail. but ill flush the whole system today to try and prevent it from failing again. thanks for all your help.
ssmandavid
Dec 29, 2015 06:01 AM
bismic
Mar 23, 2012 03:27 AM
goingape
2004 - 2008 F150
Nov 11, 2010 08:27 AM
rkshipley
Apr 23, 2006 09:54 PM
77300i6
Sep 27, 2004 06:18 AM
