'99 4.0 and timing chains
Old Jan 29, 2012 | 10:35 PM
94MustangGT's Avatar
94MustangGT
Guys, it looks like we are about to get a '99 SOHC Explorer with 130K from a family member(not my idea, and you'll see why.)
So my questions: it appears to have timing chain issues(motor sounds like a marble in a can at start up and the noise doesn't go completly away) and has been making this noise for years. Oil changes were sparadic at best. Did the lack of oil changes acclerate the timing chain issue or is it "luck" with these motors. I believe in the former, but I wanted ya'll's input. Anything you can do to quite it down aside from fixing it? Also, how long until it becomes inoperable?(the sooner the better)
Thanks gentlemen.
Old Jan 30, 2012 | 05:38 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
My BIL did a timing chain replacement on a '99 or '00 4.0L and ended up pulling the engine to get to them as they are all in the back of the engine. Once the chains and associated parts were replaced while he in there, she ran strong for years.
I think this is the nature of the beast.
Old Jan 30, 2012 | 09:09 PM
94MustangGT
^ Yes, the motor has to come out which really tacks on to the cost of the repair. They are sweet little power plants, but man this is going to be more trouble than it's worth.
Old Jan 30, 2012 | 11:21 PM
85e150's Avatar
85e150
Motor has to come out.
Delayed oil changes always hurt OHC chain tensioners, and the 4.0 is no exception.
Inoperative because of the cam chain failure means ruined valves, possibly pistons, possibly heads. Fix it NOW.
Two or three chains are in front:
--primary chain, just like a cam-in-block motor, which is what the 4.0 started out with. That runs a cam blank jackshaft.
--if 4x4, counterbalancer chain.
--driver side cam chain. This tensioner can be fixed in vehicle.
One in back:
--passenger side cam change, runs from the back of the cam blank jack shaft to passenger side head. This is the rascal that requires engine removal.
More than you want to know:
correct parts #'s 4.0sohc guides & tensioners with pics... - Ford Explorer Ranger Enthusiasts "Serious Explorations"®
Short version: Get Ford parts.
Old Jan 31, 2012 | 06:11 PM
94MustangGT
^ Sounds like this was preventable. Thanks for the info.
krick
Mar 29, 2015 01:54 PM
T18skyguy
1983 - 2012 Ranger & B-Series
Aug 19, 2014 11:35 AM
erick2719
Oct 17, 2012 12:35 PM
johnsjsj
Dec 25, 2010 12:13 AM
musclemaker
Feb 12, 2004 07:30 PM
