rear wheel
Old Jan 29, 2012 | 09:17 PM
lafermedavid's Avatar
lafermedavid
rear wheel
rear passenger wheel on my D60 1975 hb has play.I did the rear disk conv.Torqed the same as the other side,looks like Im draining and pulling axle .any thoughts thanks d
Old Jan 31, 2012 | 05:00 AM
wdfp's Avatar
wdfp
Why do you have to drain it? I don't really know what the conversion entails but if it has play I'd say you have loose bearings. If it had new bearings and races which I spose it would have with new parts. maybe a race wasn't seated all the way. How much play? I always leave a very slight amount when all is tightened, just enough you can barely feel it. or you might have got the outside nut tightened correctly but the inner was still loose. It happens... or a lot of other things could cause it too. But really, why will you drain the differential?
Old Jan 31, 2012 | 05:56 AM
lafermedavid
rear wheel
I have a high volume cover which holds more gear oil ,its new,I thought I better drain so I would not loose fluid.Any way I drained it and pulled spline,Ill get back into the hub this weekend.Thats what I thought that maybe the race didnt seat,everything is new,small leak coming out of rear seal,back to square D.Thankyou for response.
handifletch
Modular V10 (6.8l)
17
Apr 13, 2017 06:11 AM
bakerbuilttracks
17
Jan 26, 2015 10:53 PM
TD2000Merc
Apr 9, 2007 09:29 PM
F250Rob
Nov 19, 2006 08:48 PM
chickenmanq
May 20, 2002 06:00 PM
