high boy
Old Jan 29, 2012 | 11:32 AM
rpharesjr's Avatar
rpharesjr
high boy
I have a 73 short wide 4x4 W/4 speed trans . My question is , Did the short wide come in a factory lift ? Mine sits up like the long box factory lift , but when I look I can't see any after market componets . If this is factory , then it would be a pretty rare truck , wouldn't it ?
Old Jan 29, 2012 | 12:22 PM
booger78's Avatar
booger78
A highboy as we call it was never a half ton, always had divourced t-case, gas tank behind the seat, leaf springs in front. If it sits higher than a stock f150 4x4 something has been done to it by a previous owner.
Old Jan 29, 2012 | 01:49 PM
rpharesjr's Avatar
rpharesjr
Hey thanks for the info. Now I know. I plan too do alot of work to this thing. My buddy wants me to do a magor swap. He keeps trying to talk me into swapping boddies, putting my 73 onto a 96 Bronco chassis. running gear and all. I told him he was drunk haha. Isn't the wheel bases quite abit differant? Bronco being 104" and the short bed being 117". Am I right in these measurments?
Old Jan 29, 2012 | 01:51 PM
USArmyTaterness's Avatar
USArmyTaterness
One word and we solve all your problems.
Pictures.
Old Jan 29, 2012 | 02:08 PM
rpharesjr's Avatar
rpharesjr
As soon as I start my project I will post flicks. I did do a title search on this truck, and on closer inspection it does have larger coils up front. This is an F-100 with the 360 and 4 speed. It has an under bed mount fuel tank. So it is not a High Boy.
Old Jan 29, 2012 | 02:14 PM
USArmyTaterness
Check the axles maybe someone gave you a couple thousand dollar gift the Dana 60's can be up to a grand around here
Old Jan 29, 2012 | 02:22 PM
rpharesjr's Avatar
rpharesjr
Thats a good idea! Thanks I will do that. How will I know if it is? I really do appeciate all imput.
Old Jan 29, 2012 | 02:34 PM
USArmyTaterness
Find the axle code off the top my head I can not remember where but check round the pumpkin if I remember right. Also should be high pinion so the drive shaft will come out closer to the top of the housing
Old Jan 29, 2012 | 03:31 PM
rpharesjr's Avatar
rpharesjr
Well how lucky could I get? I went out into the rain and crawled around in the wet gravel the did an image search on the web, and it seems I am one lucky dude. If anyone els knows just where to look, please let me know. I will do it again just to make sure. Thanks...
Old Jan 29, 2012 | 03:51 PM
JB78f150's Avatar
JB78f150
Just take a 1/2 inch wrench out there and check the bolts on the diff cover . If it 9/16 it is a 60 and if its 1/2 it a 44.
Old Jan 29, 2012 | 03:54 PM
rpharesjr's Avatar
rpharesjr
Most excelent . I will do that now .
Old Jan 29, 2012 | 03:59 PM
rpharesjr's Avatar
rpharesjr
Darn it's a 44 . Oh well thats ok . It's still going to be a nice truck .
Old Jan 29, 2012 | 04:01 PM
JB78f150's Avatar
JB78f150
Well I be watching for pics. Glad you figured it out.
Old Jan 29, 2012 | 05:04 PM
rpharesjr's Avatar
rpharesjr
I have a little while left to pay off motor cycle , then I will be getting started on the truck . Putting in lots of ot on job . I will working on truck before spring . Thanks alot for imput .
Old Jan 29, 2012 | 05:13 PM
ogreyghost's Avatar
ogreyghost
I used to have a 75 f100, high pinion dana 44 was stock front axle with 350 gears some had single speed t-case behind toploader 4 speed- not hard then to find np205 just need to shorten driveshaft to rear and get a new crossmember from wreckin yard stock one is a bitch. mounts inside framerails top and bottom hard to remove..
