Speedometer issue
Old Jan 28, 2012 | 01:47 PM
spooky01's Avatar
spooky01
Speedometer issue
Hey guys I searched the forums to try and find the answer to my bouncing speedometer problem but they only confused me. My speedometer will every so often bounce around when driving and even while sits still. Is this the VSS?
Thanks
Old Jan 28, 2012 | 02:18 PM
BigAlsPSD's Avatar
BigAlsPSD
VSS is a cheap enough part to throw at it and see. However, I would look closely at the wiring, could have a chafed wire somewhere that is changing the values, check battery connections and conditions as well.
Old Jan 28, 2012 | 03:09 PM
spooky01's Avatar
spooky01
Got it fixed, dirty VSS. Thanks
Old Jan 28, 2012 | 03:11 PM
BigAlsPSD's Avatar
BigAlsPSD
Glad you got it fixed. Dirty with tiny metal shavings? Hopefully no large chunks.
Old Jan 28, 2012 | 11:35 PM
BobbyDiesel71's Avatar
BobbyDiesel71
which VSS sensor did you clean and replace?
How did you clean it?
Old Jan 28, 2012 | 11:37 PM
BigAlsPSD's Avatar
BigAlsPSD
I realize you aren't asking me, but the VSS was likely the one in the top of the rear differential, one bolt pop it out, it is a magnetic pickup type to get pulses from the tone ring so being a magnet, ferrous metals would adhere to it over time.
Old Jan 29, 2012 | 12:27 AM
BobbyDiesel71
thanks for the help
my speedo is working fine, I just wanted to know, just in case
Old Mar 4, 2012 | 11:41 AM
spooky01's Avatar
spooky01
Speedometer issue is back...
I replaced my VSS as instructed, jumping speedometer needle went away for a week or so, now it is back. I checked the connector and the wiring and everything looks ok. Could it be a cheap VSS as I bought it at Auto Zone?
Old Oct 31, 2013 | 02:01 PM
Lex2002's Avatar
Lex2002
When I cleaned the speed sensor on my truck, during a differential overhaul, not even knowing it was the cause of my jumping speedometer (above 55mph), it stopped the jumping. It was indeed covered with metal filings.
rvpuller
May 29, 2019 10:16 AM
Punisher29073
Jun 12, 2013 12:39 PM
ole yeller 1978
Nov 5, 2006 05:12 PM
elvis on cape
Aug 15, 2005 07:06 PM
