Any problem in CA. with smog cert running w/o a muffer?
And in the spirit of a successful forum such as this one, they all get answered over and over and over. Part of what I have noticed here is that with all the repeat questions, the veteran forum members patiently answer all of them.
I had to realign my way of thinking when I started posting here on a regular basis (a few years after I registered) because all the other forums I've ever frequented, it sure aint like that!
Stewart
So, What are you saying trey. I didn't catch it the first, 2nd or 3rd time..
on this or the other post's..
Guys here you go.. read your little hearts out on smog..
Everyone should copy this and take it with them when they go to do a smog..
http://springerpop.net/F350/PDFs/APP...%2012-2009.pdf
Damn Pop. I didn't see your post.. guess i should read the whole thread LOL
Yes, I'm just kidding.
No, it doesn't. But it doesn't need one either because ALL intake systems have been OK'd by the California Air Resource Board.
No. Same as the intake. All exhaust systems (turbo back) have been OK'd by CARB.
Just find a post by Marv (SpringerPop) and check his sig. The last time I looked, he has all the CARB smog check stuff linked in his sig.
Does your valve cover sticker state your rig came with a cat? You might also have a sticker on the bottom of your hood, next to the latch.
What year is your truck? What trans does it have?
Trey, post here long enough and you'll see the same questions get posted over and over and over and over and over and over.......
Stewart
Stewart
#28
So I read all theCARB stuff. Is there any tuners period that are CARB approved. I couldn't find any. I had mine smoged last year at a smog only place, it was easy, with my DP tuner. I know they were rejected at that time but so many more where waiting approval. Now none of that stuff applies. Anybody had luck with theirs in the last month or so.
Chet
Chet
#29
LMFAO !!! found it..
http://kalecoauto.com/index.php?main...products_id=27
#30
What do you have for the piston return springs ?
Elbow Grease [GRS08] - $6.95 : KaleCoAuto, Hard to find automotive items!
