Any problem in CA. with smog cert running w/o a muffer?
Any of you in CA. know if there is a problem running an exhaust without a muffler when getting your truck smogged? I'm looking at getting a new exhaust for my '02 F250 and don't want to have smog issues
did you try to call smog station?
Muffler is not part of emission system, so IMHO it should not matter on smog test. On the other hand CHP might pull you over for that, but they never do that to Harley owners. |
I just went to get my smog check done. The tech looked at my truck and asked if I still had the stock air filter box. he told me to put it on. He said the exhaust was fine as long as your is a non-catalyst. I'm sure all techs are different. My current air filter is a 6637.
Originally Posted by 12pump
(Post 11350798)
I was also looking at putting on a 6637 filter kit. I thought they were CA smog legal? Why did he want you to put the stock set up back on? would he of failed you if not? so tired of CA. emissions crap!:-arrgh |
Originally Posted by smithrock
(Post 11350912)
Any intake filter is CARB approved. Stewart |
Originally Posted by Stewart_H
(Post 11350982)
Because the tech is uninformed.
(Post 11350912)
Go down to the CARB web site and print out the part on the air cleaner. When I read it last it was fine on diesels to change air cleaners to any kind, along with exhaust if you don't have a cat. I just pulled a cat apart. The center section is a 5inch thick square piece that is right in the center. So you should be able to weld your four inch pipe right on to both sides of the cat without changing the inturnals of the cat. I know that isn't like removing but would let you have four inch all the way back.
Chet |
Originally Posted by Bonanza35
(Post 11351340)
Chet My truck doesn't have a cat. I'll check that website. |
Listen up. I am tired of saying this...
AIR FILTERS WILL NOT (SHOULD NOT) FAIL A SMOG INSPECTION. MUFFLERS WILL NOT (SHOULD NOT) FAIL A SMOG INSPECTION. If they do go to a new smog place. |
Originally Posted by A/Ox4
(Post 11351662)
(Post 11351662)
AIR FILTERS WILL NOT (SHOULD NOT) FAIL A SMOG INSPECTION. MUFFLERS WILL NOT (SHOULD NOT) FAIL A SMOG INSPECTION. If they do go to a new smog place. Really? Listen up? It's not like you commented on my post earlier and I'm asking YOU again! And really, (will not) and (should not) are 2 different things. But yeah I hope you're right. |
(Post 11352048)
But I'll go sit in my corner... |
(Post 11351174)
So then the 6637 kit has the CARB sticker?
I'm also looking to put on a 4" turbo back exhaust. Any problems there?
(Post 11351340)
(Post 11351360)
What year is your truck? What trans does it have?
(Post 11352164)
It wasnt really directed at any one person... It just to make a clear concise answer so any one who stumbles upon the thread doesnt have to ask it again.. :-X16
But I'll go sit in my corner... Stewart |
(Post 11352516)
Trey, post here long enough and you'll see the same questions get posted over and over and over and over and over and over.......
Stewart |
