poncholink
Old Jan 28, 2012 | 08:39 AM
PONCHOLINK's Avatar
PONCHOLINK
poncholink
is there any way to by pass interlock on89 ford 150 stick under the hood on the fender. thanks
Old Jan 28, 2012 | 08:58 AM
bashby's Avatar
bashby
Are you talking about the starter relay? What problem are you having?
Old Jan 28, 2012 | 09:21 AM
PONCHOLINK's Avatar
PONCHOLINK
yes .cant push the pedel down to make contack. just getting to old .cant pull the seat up any more thanks
Old Jan 28, 2012 | 09:39 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I think he is talking about the clutch interlock that is either on the white plastic rack attached to the pedal (like my '87) or at the firewall, mounted to the master cylinder (for ones that have the plastic pushrod)
If like my '87 you only need to jumper the two wires.
Later ones have 5 wires but only need the two light blue & red wires jumpered IIRC
bashby's Avatar
bashby
If you think its a problem with the clutch safety switch that keeps it from cranking without pushing in the clutch, look above the gas pedal, there is a connecter with at least 2 wires on it. The 2 that are red with a blue stripe are the ones you need to jump to bypass that switch, just be careful because it can crank with the truck in gear and the clutch engaged.
Old Jan 28, 2012 | 09:54 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
This thread might help you visualize it better.
https://www.ford-trucks.com/forums/1...ck-switch.html
Old Jan 28, 2012 | 11:16 AM
PONCHOLINK's Avatar
PONCHOLINK
thank you. will have to try that.no way to do that on the selanod on the fender.to old to get under the dash sorry about my spelling .poncholink
Old Jan 28, 2012 | 01:33 PM
bashby's Avatar
bashby
You'd have to run a wire to a pushbutton in the cab from the solenoid. I'd think that would be harder than jumping the clutch switch. I think the red/blue wire that goes to the clutch switch is accessible at a connector on the drivers inner fender, under the master cyl. Not 100% sure but I think you can bypass it there.
Old Jan 28, 2012 | 01:52 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Perhaps you have some mechanically inclined neighbor or younger friend who could accomplish this for you in ten minutes or less with a simple butt crimp connector?
Old Jan 28, 2012 | 04:54 PM
bashby's Avatar
bashby
Nevermind on the under hood wire, I was thinking about the nuetral safety switch on an auto trans.
Old Jan 29, 2012 | 06:01 AM
PONCHOLINK's Avatar
PONCHOLINK
THANK YOU WILL LOOK.PONCHOLINK.YOU WRE ALOT OF HELP
Steve Jepson
Jun 4, 2012 12:01 PM
coleboy11
1983 - 2012 Ranger & B-Series
Dec 3, 2011 09:42 AM
camperboy
Aug 26, 2007 08:51 PM
CJseven
Jul 19, 2007 05:13 PM
Kai
Nov 20, 2002 08:31 AM
