1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2006 Expedition FPDM / Fuel Pump issue FIXED - pics
Old 01-27-2012, 04:10 PM
sfc2001's Avatar
sfc2001
sfc2001 is offline
2006 Expedition 5.4L, approximately 130k miles... Just last month was pulling into Target parking lot - parked car in a parking spot, and while concluding a phone call (engine idling), car just died, as if it ran out of gas. Tried starting - turned over briefly a couple of times, but mostly just cranked and cranked with no result, as if it were out of gas.
Checked fusebox, noted fuse #12 was blown... Great! Got some replacement fuses - stuck one in there, cranked her up, she ran about 10 seconds before the fuse blew again. Crap.
35 degrees and saturating rain all day - stranded at the Target with kids in car!! Called a neighbor to pick us up, and set about researching my problem at home. Quickly came upon reports of the FPDM (Fuel Pump Driver Module) issues for this model year and others, whereby corrosion on the mounting bracket destroys the module. Seemed logical, and once I understood the problem (you'll see in a second) it's astounding that there haven't been more reports of this - I'm certain there will be eventually, having seen mine.
I bought the part and rigged up a quickie install right there in the rain in the parking lot - took about 10 minutes to plug in the new module. I figured out quickly that there was no way to get the two bolts off of the bracket (rusted completely on there) - so without proper tools and not wanting to get drenched, I just crammed my hand up above the spare from underneath and was able to unplug the harness connector (leaving the old FPDM mounted up there)... The FPDM is secured to the bracket with just two bolts, and there is only a single wiring harness connector plugged into it... In theory I just needed to plug the harness into the new one and then could 'dangle' it all the way home. Pulled the harness down below the spare tire, and just plugged in the new one and 'tie-strapped' it up there to hold it on temporarily. Cranked it up and drove her home - spent some time finishing the install properly in the comfort of my garage. It was easier to remove the entire bracket and get the old FPDM off of it out of the car than attempt to deal with the rusted bolts while the bracket was still installed.
Review my photos below and you'll see what I mean - every model with this type of setup will eventually have this failure - the corrosion is caused by what is called 'dissimilar metal corrosion', where someone was asleep at the wheel during design time and opted to mount the aluminum-backed FPDM directly against a non-aluminum metal bracket. The nasty corrosion you see below isn't due to winter or weather but simply the two dissimilar metals being in contact with one another. The only way to prevent this would be to keep them from touching - which as you can see from the photos, the redesigned FPDM (over $100 for the part at my dealer) has new spacers built into it to keep it physically separated from the non-aluminum mounting bracket.
Anyway I had meant to post this last month as I saw no real thorough posts anywhere detailing this repair (which I think will become quite common as time progresses). Hope this helps - if you're having sporadic fuel pump or 'engine dying' issues that are not explained, look here first. I did see many early folks who erroneously replaced entire Fuel Pumps (a tough/expensive job on this car), only to have the issues maddeningly continue. I understand also that it is possible for the malfunctioning/shorting FPDM to cause failure of the Fuel Pump itself - so it's important to get it fixed if you're experiencing the symptoms.
Good luck...!
Here is the location of the FPDM when viewed from the left rear tire area - the bracket is circled (and my 'temporary' install job can be seen in the square red box hanging down
Here is the temporary install job up close - tiestrap did just fine
Here is the new FPDM design mounted onto the old bracket - arrows pointing to the new spacers:
Here is the amazing pic... This is the old FPDM after removal from the bracket... The corrosion was so bad in some places I could take a pencil and gently push thru the destroyed backing - was almost soft to the touch - amazing (yours will look the same eventually!)
Old 01-27-2012, 09:56 PM
Boat Tug's Avatar
Boat Tug
Boat Tug is offline
Well I'm impressed at your diagnosis, field repair, finish repair and that you reported back all that good info.
Good job all around
Old 01-27-2012, 10:36 PM
SRB1118's Avatar
SRB1118
SRB1118 is offline
Sounds familiar....
Recently had the same problem, shop replaced but still not entirely convinced. My wifes '06 has had intermittent "bogging" over the past few months noticable when going between 45-55 mph. As you would start up a grade or long hill we would feel what appeared to be some sort of interruption in the drive line. Almost like a sloppy u-joint, or as one mechanic described as a "fish bite". Once you would crest the hill it would disapate and smooth out....
History is fuel pump replaced in May '11. Ran fine up until recently as mentioned.
Fast forward to a week ago....wife comes out of work and would start and idle, as soon as she would put into gear it would stall. Once on the scene, I let it idle for ten minutes or so and managed to get it into gear and drive it around the lot for a bit to see if I could nurse it. The engine light did come on during all of this, and with a local parts store just down the street, I drove it in to have them read the code. The young man tells me "it says you got a fuel pressure issue, try changing fuel filter first". I replaced fuel filter and drove it for another day...seemed to be doing ok until Saturday morning. Started to run horrible under a load, cutting out all the way up any grade. Stalled, engine light reappeared and would not start. Towed to repair shop as at this point I am pretty baffled. Once on the scanner, they determine that a fuel sensor is bad, replaced it and said come and get your vehicle. Well, $192 later we were on the road...for about 15 minutes. Started to do the exact same thing, of course by now it is after closing time so I drive it straight to them so they would have to see it first thing the next morning. Mid morning they call me and tell me once again they found the problem. Said you got to see this part and you will understand. It was the FPDM...looked a little worse than the one in the pics (can you say recall?). The whole back was ate through exposing the internals, which appeared to be a small computer mother board. Through the codes that appeared they blamed the faulty FPDM for frying the fuel sensor, hince the continued bogging and cutting out after new sensor. Good thing I took it back up or probably would have fried the new sensor.
HOWEVER....here's where I'm not completly convinced our problem is solved. It is still cutting out or "fish biting" while climbing a hill. Hard to explain, but picture running a smooth 30 mph plus when you approach a long or short grade. Seems as if when you start into the hill and as the fuel system calls for more to accomodate the load....it misses, or cuts out for short periods. Only a few, but definatly there. Not as bad as before but apparent. No engine light yet, so I know the shop is gonna give me the dumb we don't know look Monday morning when I show up with it again. Just hoping someone out there could at least point me in the right direction here....? Thanks in advance and sorry for the long winded story. Just wanted to paint a vivid picture.
Old 01-28-2012, 12:05 PM
sfc2001's Avatar
sfc2001
sfc2001 is offline
Hmmm. Sounds like you ran with the new fuel sensor for a little while with the shorted FPDM before they figured out it was the FPDM. While I was fortunate that my failure was "total" and therefore fixed right away (before other damage could be done by the faulty signals, as it causes havoc in the fuel system) I have seen other reports of associated systems (sensor, pump itself, etc) failing as a result of the FPDM corrosion issue. There is real electrical or physical damage that could occur within the fuel circuit depending on how your specific situation manifested itself. Usually just engine dies; but, could be more subtle...
It's possible there is other related damage that had occurred, or perhaps the new sensor became damaged even from the short amount of time it was running with the old FPDM. I know it's not what you want to hear but maybe provide some additional ideas.
There is also a fuel pump relay (on my 2006 anyway) built into the fuse box - requires replacing the fuse box - it's also one of the several areas to investigate, though your intermittent situation makes it trickier. If it were me I'd start at the fuse box and work my way back testing all of it. There are a variety of posts I'd found on the many manifestations of this thing - all caused by this FPDM problem.
Good luck...
Old 02-02-2012, 04:30 PM
mig25's Avatar
mig25
mig25 is offline
fuel sensor
I removed FPDM today, had corrosion and a hole on it, truck was running fine.
I cleaned it out , used a wire brush to make it shining, I patched the whole with JB Weld epoxy. Painted it , removed the bracket , sanded painted the bracket, I installed it back with longer screws and two stailess steel spacers.
Thanks for help me prevent this problem on my truck.
My Advice , if you have an expy please remove yours do the same thing.
It is well worthy preventative maintenance.
Thank you.
Old 02-02-2012, 05:54 PM
sfc2001's Avatar
sfc2001
sfc2001 is offline
Good deal
Yeah sure beats engine dying at 70mph or in nasty weather... Or when the wife or kids are driving... Or in Tim-buck-too where no dealer is around for miles (dealer-only part
Old 02-03-2012, 09:46 PM
totalrecall's Avatar
totalrecall
totalrecall is offline
Do any of you know, is that the same issue for the older models, ie like mine a 2001? Just curious of course.
Thanks
Mike
Old 02-04-2012, 07:18 AM
lv2race's Avatar
lv2race
lv2race is offline
That part didn't hit the Expo until about '05.
Old 02-04-2012, 11:14 AM
thecardoc's Avatar
thecardoc
thecardoc is offline
This part is available thru Dorman #590-001 as low as $55.00 if you shop around.
It fits 2004 -2008 F series, Explorers, and Lincoln.
Old 02-04-2012, 11:53 AM
sfc2001's Avatar
sfc2001
sfc2001 is offline
Man that's sure the way to go if you're doing preventative (not needing in a pinch like I did). The Dorman part even has the new spacers. $55 beats $130-ish I paid for dealer part. Good to know!!
Old 02-05-2012, 05:24 PM
timberwoof's Avatar
timberwoof
timberwoof is offline
Good Work. Will have to get up under mine and check it.
Old 01-01-2013, 09:43 AM
kurtwt's Avatar
kurtwt
kurtwt is offline
Hey all, I am having the exact same issue with my 06 Expedition Limited, 124,xxx miles. Wife complained about a sputter or lose of power about 2 weeks ago, Ran good for about a week then 4 days ago i was pulling out of a parking lot and it just died like it ran ran out of gas. Poked around for about 30 minutes checking fuses. After the 30 minutes or so it started up like nothing ever happened and ran fine. Then it happened again 2 days ago in the middle of an intersection! Sat there for 30 minutes then it started fine. This happened twice in the same day but the last time resulted in a tow home as it has not started since. After reading this thread i am heading out to the garage to pull the fpdm out of the truck.
In response to SRB1118,
I had this exact same issue with mine, felt just like a tranny slipping or a bucking sensation but only on a slight grade under a little load. No codes nothing on the computer. I took the truck out and beat on it and got the engine light to come on, codes reported "misfire on #2 and #7 cylinder"
So I replaced the coil packs on #2 and #7 and replaced the plugs ( i wont get into that, Thats a whole other thread) Its been running great ever since until now with the fpdm.
Old 01-01-2013, 11:16 AM
mig25's Avatar
mig25
mig25 is offline
WOW
I can't believe the truck is telling you something is wrong , I am about to die , yet you still drive untill it is completelly dead.
I guess it is just me.
Any little sign of anything going wrong , I try to find out and fix immediatelly.
I fixed this Fuel pump module way before it acted up at all. I found this post.
Checked my module , it waws corroded. I fixed it . Never had an issue.
Old 02-25-2013, 04:28 PM
ChocNav's Avatar
ChocNav
ChocNav is offline
Thank you sfc2001!!!!
Your post saved me hundreds of dollars and a lost weekend.
I thought i would list my symptoms in hopes of helping others. My wife's 2005 Navigator with 78k started but as she pulled out of her Costco parking spot it died and she could not get it started. When I got there it would start but was missing bad and died after 5-10 seconds. After trying it a couple times it stopped firing and would crank over and over (I think this was when the fuse blew).
I went home did a search and found this post. I ordered the new FPDM from Advance Auto that night and they had it 9:30AM the next day. Fixed it in the Costco parking lot and drove it home to mount properly.
A key piece of this whole thing is both of us had trouble on a humid/rainy day which aggravates the electronics. After seeing fuse #12 was blown I knew it the FPDM was the issue. Prior to that day on humid/rainy days it would miss occasionally. I changed the plugs thinking that was the issue but it ultimately turned out to be the FPDM.
Old 05-03-2014, 12:15 PM
2k5EXP4104's Avatar
2k5EXP4104
2k5EXP4104 is offline
I realize the thread is dated but I believe I am going through this right now. The 2005 exp was running rough and then hit a patch of rough starting. Cranking fine but just wouldnt turn over. Then it has a patch where it wont start and the check engine light comes on. Lacking time to troubleshoot prior to a work trip and needing an oil change, I took it the local lincoln dealership. $800 later they tell me that with the oil change, a full tune up and replacing a bad coil and all the spark plugs that they have a "partial" fix but since they cant recreate the trouble starting they are stuck with just hoping it doesnt go out again.
So needless to say I am upset, all that money and it still is having issues-just conveniently not while its there. I am going to try this fix tomorrow and I'll let you know how it goes.
Quick Reply: 2006 Expedition FPDM / Fuel Pump issue FIXED - pics
