Starting Issues
Old Jan 27, 2012 | 11:24 AM
GunnyBeaty's Avatar
GunnyBeaty
Starting Issues
Ok I start the truck up drive into work make a quick stop and itstarts right back up. Get to my final destination and need to make a run across the base. Turn the key ...click click. then i notice there are no dash lights or the radio even working. I get a boost and CLick click then no lights again. tap the solenoid and the lights come on. So i replace the solenoid and i get the same result. nothing. Any ideas. Could it be a fuseable link or just a really dead battery?
Old Jan 27, 2012 | 11:39 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Have the battery load tested to eliminate that from the equation. Even a new solenoid can be bad, lot of cheap parts anymore. Your connections to solenoid should be good since you just changed it, but make sure the mounting screws are grounding it properly. The fuse link is close to the solenoid so visually inspect it. Check neg battery cable where it grounds to block, clean and reconnect. Loosing all power, points to a bad connection to battery or ground. That'll get you started finding your issue.
Old Jan 27, 2012 | 01:27 PM
GunnyBeaty's Avatar
GunnyBeaty
Yeah just came back in. Went out removed some wires and cleaned the connections . really i gave up on it but as i started to walk away i hit the switch one more time and voila! Purring like a kitten. Thanks for the help
Koremark
Sep 12, 2017 09:53 PM
axidjw
North Carolina Chapter
Jan 6, 2017 02:06 PM
Jere Miah
Feb 9, 2016 06:41 AM
GunnyBeaty
Feb 16, 2012 12:14 PM
FordPickup460
Apr 6, 2004 08:54 PM
