New chip install problem
Old Jan 26, 2012 | 07:16 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Originally Posted by Bill97
Sorry if this was already mentioned, I'm at work and didn't read all of the posts. Also I apologize for stating something so simple, as I'm sure it was checked - with my TS chip the security setting will not allow the truck to start and the WTS light will stay on. Did you click it to a different setting?
That setting works well when a girl friend wants to drive your rig. You tell her she can drive if she can start it. So far she has not figured it out.
Hahaha i know what setting im getting reburned
Old Jan 26, 2012 | 07:46 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Originally Posted by tlapham
I cleaned it well, after it wouldn't start the first time i cleaned it again, but still nothing... I can't see the back side of course, but i scrubbed it twice as much as i did on the front side just to make sure...
Quit being lazy and do the job right.
Take the PCM out, take it apart, and CLEAN IT.
Old Jan 26, 2012 | 07:47 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Originally Posted by superduty4x4
Your chip wasn't burned correctly, it needs to be reburned. Been there, done that.
So not having clean J3 contacts on the PCM circuit board means the chip isn't "burned" correctly?
Jump to conclusions much?
Old Jan 26, 2012 | 08:08 PM
fordpride's Avatar
fordpride
Someone get Cody a drink
Old Jan 26, 2012 | 10:49 PM
tlapham's Avatar
tlapham
OK, sheesh. tomorrow...
Old Jan 26, 2012 | 11:20 PM
oldbird1965's Avatar
oldbird1965
It's possible to 'over' scrub the contacts.
Old Jan 27, 2012 | 12:26 AM
chicagodragon's Avatar
chicagodragon
I herd it is. That us a very thin layer if copper you are cleaning, easy to rub off
Old Jan 27, 2012 | 12:28 AM
Ford4Life7.3
Dont take it personal lol, thats just Cody. He's like me in that we lack the filter in between our brain and mouth. But he is right, like Mike and he said, to do it right it needs to be out of the truck. If you scrubbed without being able to see the contacts you may have been scrubing something you shouldnt've.
Old Feb 6, 2012 | 10:09 PM
tlapham's Avatar
tlapham
Still no worky with the stupid thingy plugged in...
Ok, well after many attempts, i still can't get the dang thing to work. What a PITA. I have used paint thinner, rubbed and rubbed, scraped off the surfaces with a small screwdriver, and scrubbed with a scotchbrite pad until the copper is showing on every terminal.
I would spend more time on it but I need the truck! I guess the next step is to remove the cover from the box, and check continuity from the chip to the computer board...
Old Feb 7, 2012 | 02:25 AM
richdawg's Avatar
richdawg
Originally Posted by Ford4Life7.3
Was it a out of the box TS? Or did it have custom tunes( PHP, TW, etc)?
Please answer this question, we need to know.
Where did you get it, was it new or used?
Old Feb 7, 2012 | 02:45 AM
tlapham's Avatar
tlapham
Sorry, there are so many responses i missed that one. It is out of the box, pretty standard tunes including a stock tune to go from.
Old Feb 7, 2012 | 02:59 AM
richdawg's Avatar
richdawg
X----2
You may have over cleaned the contacts. I don't think there should be any exposed copper. My reasoning is that copper is very corrosive and only makes a good contact for a short time before corrosion starts in the contact areas. What I have experienced is the board traces and surface mount pads and thru hole eyelets all get soldered after parts are loaded on the board, usually done in mass production running the boards over a solder wave machine, coating the usually nickle or copper traces with solder. So I would assume the manufacturer of the chip coats the contact area with a coating or something that needs to be removed for good contact during installation. They really should send good instruction on how to do this installation process.
Old Feb 7, 2012 | 03:18 AM
  #28
richdawg's Avatar
richdawg
The pictures you took look really nice, if you could take some good close up pics of the contact areas you cleaned (both sides of the board) we may be able to see if there is any damage done to the contact areas.
Old Feb 7, 2012 | 06:59 AM
  #29
DIYMechanic's Avatar
DIYMechanic
Are you sure the chip is burned for your PCM code?
Old Feb 7, 2012 | 07:06 AM
  #30
fordpride's Avatar
fordpride
I would send the chip back and get another one
