Sponsored by: Auxito
3157 LED bulbs
Old Jan 26, 2012 | 12:02 PM
00GT's Avatar
00GT
3157 LED bulbs
I have a question. I want to replace my rear 3157 brake/tail light bulbs on my 03 screw. With LED bulbs. The old bulbs serve as the brake and running light. The leds are one I guess...does anyone have these and do they work correctly?
Old Jan 26, 2012 | 05:18 PM
Bluegrass 7's Avatar
Bluegrass 7
You may have a problem doing this.
The reqular bulbs have low resistance to operate the flasher and even affect the transmission operation.
The LED operates on very little current so is not enough to be sensed correctly.
There is a work around for this but you will have to dig that info out yourself or someone here could supply it..
I don't reccomend you do it.
Good luck.
Old Jan 26, 2012 | 05:25 PM
86F150302's Avatar
86F150302
You are going to need an electronic flasher and load resistors.
Old Jan 26, 2012 | 06:05 PM
00GT's Avatar
00GT
Sounds complicated.. I think ill stick with the stock ones. I have LEDs in the reverse lights, license plate and the whole interior looks pretty sweet. I have euro tail lights and just wanted to add some leds.
More trouble then its worth
Thanks guys
Old Jan 26, 2012 | 06:11 PM
86F150302's Avatar
86F150302
Not complicated at all. you just plug the flasher in and splice the resistors online of the less.I've converted my whole truck to led.
Old Jan 26, 2012 | 06:12 PM
86F150302's Avatar
86F150302
Wow auto correct.... Inline** LEDs**
Eightyfive Flareside
Electrical Systems/Wiring
Nov 18, 2023 06:03 AM
joninflorida
Feb 14, 2019 12:52 PM
TexasGuy001
32
Mar 25, 2018 03:00 AM
Jag Red 54
N. California Chapter
Sep 4, 2013 11:04 AM
piedmont929
Nov 23, 2008 04:53 PM
