Hood mods
Old Jan 26, 2012 | 02:29 AM
Steve Christensen's Avatar
Steve Christensen
Hood mods
Gidday guys, it's Australia Day here today 26th, public holiday.Last weekend I came to the conclusion I'll have to add 1 1/2'' to the rear of the hood to get it to fit nicely, something I was trying to avoid but because the cab isn't quite where it should be I'll have to.
As you can see I've started welding in a strip of panel steel.
The hood will be bolted to the fenders sitting on spacers of a similar size to the original welt.
Hope you guys are doing OK,
Regards, Steve.
Old Jan 27, 2012 | 07:25 AM
2Ton47's Avatar
2Ton47
I have a problem with my hood at the other end. There's about a 3/4" gap between the hood and the surface below but only at the front one foot or so. It also closes a little off center. I've tried everything but can't correct it so I'm just going to live with it.
Maybe the truck took at hit at some point and threw things out of wack.
Old Jan 27, 2012 | 08:34 AM
COMPLIT1107's Avatar
COMPLIT1107
2ton....
Close your hood, so that it appears "in-place". Loosen the nuts (bolts) on the inside of the cowl (behind kickplates), then push the hood, and wiggle the hood (without opening it) to get it into what you think is good. Snug up the nuts (bolts) and open and close hood to see if it is better. Repeat process until you are happy or frustrated ! Most of the pressure should be applied at the cowl side of the hood.
Old Jan 27, 2012 | 08:55 AM
2Ton47's Avatar
2Ton47
Originally Posted by COMPLIT1107
2ton....
I did try that but there doesn't seem to be much adjustment there. I was thinking of making those holes bigger. I will probably try again.
Thanks
sdrob15
Nov 11, 2018 09:20 AM
thepitshop
24
Sep 22, 2016 07:56 PM
glassmanbruce
Jan 15, 2016 04:19 PM
FunknFord
Nov 24, 2011 10:05 AM
dale gribble
Oct 31, 2005 04:03 PM
