1980 302 performance
Old Jan 27, 2012 | 05:38 PM
  #31
LARIAT 85's Avatar
LARIAT 85
If you build up the 302 and leave those tall 3.00 gears in it, it will never feel powerful and you won't ever be satisfied with your truck.
Old Jan 27, 2012 | 05:53 PM
  #32
rangergirl94's Avatar
rangergirl94
I have a c6 and I was planning on lower gears but torn between 3.50 or 4.10 like I said it sees some road use and want to put a nv435 in her
Old Jan 27, 2012 | 06:12 PM
  #33
LARIAT 85's Avatar
LARIAT 85
A C6 is really going to scream on the highway with 4.10 gears. If you're going to run stock size tires, I would recommend 3.55 gears with a C6 if you are going to do much highway driving.
Old Jan 27, 2012 | 06:26 PM
  #34
rangergirl94
Im running 31s
Old Jan 27, 2012 | 06:57 PM
  #35
1983F1503004x4's Avatar
1983F1503004x4
Originally Posted by rangergirl94
Im running 31s
Go with the 3.55's then.
My 300 is talkin' at about 2950 rpm at 65 mph with 31's and 4.10s. That's without overdrive, just like your C6.
Although...
If it's a farm truck, it won't matter. Theoretically, if it's never going to go on the road, you could put 4.88's in it.
If there is a random chance you put it on the road, you'll want the 3.55s.
Old Jan 27, 2012 | 08:30 PM
  #36
Anafiel's Avatar
Anafiel
I thought 3.55 gears indicated a 8.8 rear? That's what I have in my Bronco's 8.8, and 3.50 in my pick-up's 9".
Did I miss something?
Old Jan 27, 2012 | 09:27 PM
  #37
Gary Lewis's Avatar
Gary Lewis
Nope, you missed nothing. Right on the money.
Old Jan 27, 2012 | 11:08 PM
  #38
1983F1503004x4
I don't know if you missed something but I definitely did.
How does the gearing indicate which rear end you've got? Wouldn't that be the axle code?
My 83 has an 8.8'' rear and came factory with 3.08 rear gears.
(I wish it was a 9'', but an 8.8 is fine with me).
Old Jan 27, 2012 | 11:18 PM
  #39
rangergirl94
My truck has a 9 inch it has 3.00 gears they offered 2.75 compared to 8.8 2.73 or 3.50 compared to 8.8 3.55
Old Jan 27, 2012 | 11:20 PM
  #40
85e150's Avatar
85e150
Some ratios are specific to the 8.8 vs. the 9.
3.55 = 8.8; 3.50 = 9 for example.
3.08/3.00 would be another, and maybe a few more. Of course, it's not a 100% method to determine the axle type.
A 1980 should be a 9'er out back.
Old Jan 27, 2012 | 11:59 PM
  #41
Anafiel's Avatar
Anafiel
Yea, what he said.
Old Jan 28, 2012 | 12:20 AM
  #42
rangergirl94
Did they offer gear ratio between 3:50 & 4:10?
Old Jan 28, 2012 | 01:47 AM
  #43
85e150's Avatar
85e150
In the 9 inch, several including 3.70, 3.89, 3.91.
Old Jan 28, 2012 | 02:01 PM
  #44
rangergirl94
Are they offered in the d 44 ttb for the front
Old Jan 28, 2012 | 02:40 PM
  #45
Anafiel's Avatar
Anafiel
Dana 44 Ring & Pinion Sets | Dana 44 Positraction Units | Dana 44 Differential Parts-drivetrain.com - Drivetrain.com
