Need a trailer hitch.
Old 01-25-2012, 07:58 PM
konawizard's Avatar
konawizard
konawizard is offline
91 F-250 4X4. Needing a 2" reciever hitch for it. Can I make a deal with someone? I would love something I could simply bolt on.
Old 01-26-2012, 07:34 AM
bashby's Avatar
bashby
bashby is offline
check local salvage yards.
OneTonSoup's Avatar
OneTonSoup
OneTonSoup is offline
A salvage yard might have one for you. Here's a handy hint... look not just for ford '87-'96 hitches, but also for Dodge Dakota or Ram early 90's. I say this because I had a '96 Dakota and got a salvaged class IV hitch to put on it. I never installed it before selling the truck. Later when I got the '94 F350, I was looking at that hitch and it looked similar in size to the ford's frame. I held it up to the frame and, voila, it fits perfectly. Now, there is a chance that the salvage yard sold me the wrong hitch, so if you find a dodge hitch for your ford, doublecheck the dimensions before buying it.
good luck, peace out, cheers...
Old 01-26-2012, 03:19 PM
icntdrv's Avatar
icntdrv
icntdrv is offline
I just bought a Class 5 hitch on eBay for $125 by searching for the model number referenced by Curt. They had it listed for a 1977 dodge D250, but it mates up to my frame just fine.
Old 01-26-2012, 05:42 PM
matt167's Avatar
matt167
matt167 is offline
Most of those hitches will work on just about anything.. Put a Class 5 Valley on my fathers '72 C10. listing on the side of the box, had just about everything covered. '60-'87 Chevy, Dodge from like '70-'93, Ford from like '80-'96. we took it out of the box figuring it wasn't going to fit right, but the center bar was drilled in a few places, and it lined up and fit nearly perfect, only lost the spare tire carrier.
Old 01-26-2012, 05:53 PM
bashby's Avatar
bashby
bashby is offline
I have seen those universal setups at wal mart and elsewhere, but I have seen few on trucks that I have worked on. (professional mechanic for 20 yrs) Most are vehicle specific so unless the frame is the same width it wont be real easy to make the wrong one work. On my 88 toyota I tried one from a full size chevy, and the toyota frame was quite a bit wider than the chevy.
Old 01-26-2012, 06:59 PM
matt167's Avatar
matt167
matt167 is offline
I think it was specific enough that the frames are close in width.. As I remember, there were only 2 sets of holes for the width. Dodge and Ford used the inside holes and Chevy used the outside holes IIRC.. it went up in less than an hr.
Old 01-26-2012, 08:16 PM
slam1991's Avatar
slam1991
slam1991 is offline
where about are you?
Old 01-27-2012, 04:48 PM
Slowroll90's Avatar
Slowroll90
Slowroll90 is offline
Mine was about $140 new at U haul
gijim2k1
2004 - 2008 F150
04-15-2012 06:04 PM
smashclash
11-06-2010 07:52 AM
mikefender
10-12-2007 12:13 AM
30over
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-17-2004 05:24 PM
frdcowboy
01-30-2004 12:14 AM
Quick Reply: Need a trailer hitch.
