96 7.3L powerstroke
Old Jan 25, 2012 | 04:53 PM
Mahixon's Avatar
Mahixon
96 7.3L powerstroke
Need some input. F250 4X4 Diesel, Auto trans, 172,000 miles. When i am crusing at a steady speed. The almost feels like it has a miss, but it is not a dead miss. Its not hard just a constant little jerk. I do not feel it when I accelerate or I am just sitting still and racing the engine. I have no water in the fuel, air & fuel filter are good. I had this same feeling sometime last year and it went away. Any Ideas??? Thanks David
Old Jan 25, 2012 | 05:02 PM
fordpride's Avatar
fordpride
I has a issue like that and it was a bad spot in the TPS (throttle position sensor) bottom sensor on the go pedal. If you have a good multimeter you can test it. Put black to NEG. post on battery and red in the middle wire on the TPS plug and with key in run position slowly press the pedal and watch for and flat/dead spots in the voltage
Old Jan 25, 2012 | 05:04 PM
fordpride's Avatar
fordpride
Are if you have cruise control get the truck up to the speed where it acts up and set the cruise and see if it goes away
Old Jan 25, 2012 | 05:21 PM
Mahixon's Avatar
Mahixon
I was wondering if that was a possiblity, I will check it. Thanks
Old Jan 25, 2012 | 05:31 PM
stainlessstroker95's Avatar
stainlessstroker95
You might check the fpr screen also. It is in a hole close to the top drivers side of the fuel bowl.
Old Jan 25, 2012 | 06:56 PM
strokin'_tatsch's Avatar
strokin'_tatsch
TPS(throttle position sensor) is the top sensor. IVS(Idle validation switch) is the bottom sensor.
Old Jan 25, 2012 | 07:04 PM
fordpride's Avatar
fordpride
And I knew that good save
eberlestock
Jun 7, 2015 08:43 PM
wolff7.3
Apr 8, 2014 01:35 PM
pismo874
Nov 30, 2008 09:32 PM
vinman46
Sep 20, 2004 06:39 AM
spartamouse1
Mar 25, 2002 11:20 AM
