Coolant Filter Change
Old Jan 27, 2012 | 03:48 PM
chetspencer's Avatar
chetspencer
I'm considering changing from bypass to full filtration as filter blockage is a non issue for me (see photo below) I've got over 1k miles on my whole house sediment filter with no problems.
Old Jan 27, 2012 | 04:01 PM
69cj's Avatar
69cj
If you go inline filtration and the filter should plug, your going to overheat.
Old Jan 27, 2012 | 04:09 PM
chetspencer
I could be mistaken, but when in AC max, the circuit is shut off. Maybe I'm wrong on this.
Old Jan 29, 2012 | 05:36 PM
GeneLaw1's Avatar
GeneLaw1
That's a good looking filter right there...did you put that together yourself?
Old Jan 29, 2012 | 06:14 PM
MisterCMK's Avatar
MisterCMK
Gene, what kind of law do you specialize in??
Old Jan 29, 2012 | 06:15 PM
chetspencer
Thanks! This is a work in progress. I scrounged this set-up together from various places like home depot and walmart and Napa Auto parts for the hoses. This is a 10" whole house filter. $35 at Walmart.
I just changed the filter today actually and was happy to find only about 1 table spoon of rust.
The filters that come with the housing are not compatable with the temperatures involved, so I'm looking for the correct replacement cartridge filter.
If anyone has suggestions I'm open. I found a good selection from Mcmaster Carr but I'm not sure which is the best choice.
McMaster-Carr
I'm thinking of trying the Polyester/Type 304 Stainless Steel raTED FOR 275*F
If anyone wants to try this you must use silicone grease on the o-ring or it will leak. The clear poly part of the housing has micro heat cracks but seem superficial at the moment.
Old Jan 29, 2012 | 06:17 PM
69cj's Avatar
69cj
Does that mean you will always be in a/c max?
Old Jan 29, 2012 | 06:20 PM
chetspencer
Not at all. I'm just saying I believe there is no risk of overheating by running my setup as full filtration with no bypass. I could be mistaken on the circuit involved.
Old Jan 29, 2012 | 06:22 PM
69cj's Avatar
69cj
I'm no tech but I do believe you'r wrong. Maybe a tech will chime in.
Old Jan 29, 2012 | 06:24 PM
chetspencer
maybe someone else will chime in on this. I'd like to fully understand the function of the vacuum control valve in the heater circuit.
Old Jan 29, 2012 | 06:26 PM
MisterCMK's Avatar
MisterCMK
He is filtering the full flow of the heater core. If the filter plugs then it is going to have no heat.
Old Jan 29, 2012 | 06:28 PM
chetspencer
Yes sir, and no risk of overheating, actually more coolant flowing to the Oil cooler. Correct?
Old Jan 29, 2012 | 06:36 PM
  #28
GeneLaw1's Avatar
GeneLaw1
Chris,
My practice areas are Criminal, Personal Injury, Estate planning, and I dibble in some other areas from time to time as needed!
Old Jan 29, 2012 | 06:38 PM
  #29
garndog's Avatar
garndog
is the reusable inline filter from Radiators r us worth using? has anyone used it? its 45$ and seems like it would work but im not sure. let me know please.
Old Jan 29, 2012 | 06:44 PM
  #30
69cj's Avatar
69cj
Gene, wether I'm right or wrong that system is impressive looking.
