tilt wheel
Old Jan 24, 2012 | 09:46 PM
FordOwnerJoey's Avatar
FordOwnerJoey
tilt wheel
Im not sure if the 8th or 9th gen trucks ever came with a tilt wheel/steering column, but if they did, would one be able to fit my 87 f150? (300-six, 4x4, 4 speed)
Old Jan 24, 2012 | 09:55 PM
Midnite1987's Avatar
Midnite1987
My fathers 91 had a tilt wheel which should be the same as the 87 ones
Old Jan 24, 2012 | 10:00 PM
djf150's Avatar
djf150
yepper 87-91 would be the same
Old Jan 24, 2012 | 10:12 PM
FordOwnerJoey
ok, because I might need to replaced my column anyway and would like having a tilt wheel, even though its just a standard cab, would having it tilt make it any taller? Im a tall guy and have a bench seat in there thats from a 93 so its a little taller than my old one too, makes it a little difficult getting in and out
Old Jan 24, 2012 | 10:21 PM
Midnite1987
It would tip up farther
Old Jan 25, 2012 | 04:59 AM
tjc transport's Avatar
tjc transport
i ain't rite
same column same length.
Old Jan 25, 2012 | 08:17 AM
FordOwnerJoey
ok thanks all, Im going to keep my eye out for one in the JY next time Im there
Old Jan 25, 2012 | 08:37 AM
preppypyro's Avatar
preppypyro
Too bad ya dont live closer, I got two of em from automatic trucks that are probably gonna end up going to the dump!
Old Jan 25, 2012 | 08:47 AM
FordOwnerJoey
That is too bad
Old Jan 25, 2012 | 10:34 AM
deeznuts822's Avatar
deeznuts822
You may or may not know, but pushing the turn signal lever toward the dash operates the tilt. Don't know if yours is equipt with it but i have only seen one around here WITHOUT tilt
Old Jan 25, 2012 | 12:40 PM
FordOwnerJoey
Ive tried that before, either its seized up or its not equipped, I doubt it has it, its a bare bones stock fseries, no special edition or anything, Ill look and try it again, but I doubt its already tilt, might crap my pants if it is though
Old Jan 25, 2012 | 01:52 PM
Big_Al59's Avatar
Big_Al59
Maybe the 93+ are different than the earlier ones but mine has a separate lever for tilting the wheel. It's about 2" below the turn signal. Tilting the wheel all the way up should give a little more leg room.
Old Jan 25, 2012 | 03:06 PM
tjc transport
i ain't rite
yup.pre 92 used a separate lever for tilt function.
and non tilt columns were standard in plain jane trucks. it was a rare event for a tilt wheel to be installed in a custom.
Old Jan 25, 2012 | 05:03 PM
deeznuts822
I think you mean post 91. 88 -91 use one lever, the turn signal switch
Old Jan 25, 2012 | 05:08 PM
tjc transport
i ain't rite
correct. i had the years reversed. 91 ab older was the directional switch lever. 92 and newer was a separate lever.
