06 navigator seized engine
Old Jan 24, 2012 | 10:10 AM
ineedtolearn's Avatar
ineedtolearn
I have an 06 navigator with a seized engine. will a 5.4 3 valve bolt to the nav's 6 speed transmission
Old Jan 24, 2012 | 02:00 PM
Ironhand03's Avatar
Ironhand03
Bolt to it yes. Will it work? Maybe
You need to list specifics on what you have versus what your trying to go to. Switching from one trans to another isnt likely going to work. Switching motors seems to be alittle easier. But the 5.4 3V has cam phasers and some of the sensors sre in different locations.
Does the Navigator have a 5.4 4V?
Old Jan 24, 2012 | 03:07 PM
ineedtolearn
the engine in the 06 navigator is a 5.4 3 valve, the transmission is a 6 speed.
i would like to take an engine out of an 04 f150 which also is a 5.4 3 valve and replace the blown motor in the navigator. i'm just not sure if it would be compatible with the navigator's 6 speed
Old Jan 24, 2012 | 11:06 PM
Ironhand03's Avatar
Ironhand03
If both trucks have a 5.4 3V then it should be very easy to swap the engines. You might have to grab parts from your old engine if something is different but it should be a fairly easy swap.
Old Jan 25, 2012 | 12:58 AM
ineedtolearn
thanks for your help,this is my first ford, so i appreciate the advice
Old Jan 25, 2012 | 05:34 AM
Ironhand03's Avatar
Ironhand03
No problem.
Where are you located?
Old Jan 26, 2012 | 08:05 AM
ineedtolearn
Manitoba Canada. i bought the Navigator with the motor blown, i didnt think changing the engine would be an issue. i Just want to make sure the engine i buy will work
Splinter82nd
Garage & Workshop
Apr 23, 2015 11:16 AM
Kaslothedog
Modular V8 (4.6L, 5.4L)
16
Jul 10, 2013 12:02 PM
BearFootCustom
2004 - 2008 F150
Mar 9, 2011 08:31 PM
