Ignition Pro's - Help!!
Old Apr 21, 2003 | 12:07 AM
rleeds's Avatar
rleeds
'85, F150, 351W, manual tranny, 4WD, 6", 35x10's
I have an F150 and just removed the I6 and dropped in a 351w out of an '86 Bronco. However, the salvage yard guy said that the 351w was a transplant from an unknown year. I installed the radiator, alternator, motor mounts, etc. and all the "normal" engine mounted accessories from the donor truck.
Everything went smooth until I tried to start it with the new engine. There is no spark coming from the coil. I am thinking that the ECM from the '85 I6 is for a computer controlled engine and the ECM needed for the 351w is non-computer controlled. There are definitely a lot less wires and less sending units on the 351w than were on 300 I6. I am guessing that the 351w is around a '79. Can't find where the serial number is on the engine to corroborate the year. Gut feeling is around '79.
I did not get the ECM module from the donor. Am I headed in the right direction? Should I have gotten the module and bypassed the truck's original computer?
Note: the alternator has a wire that isnt connected. It is yellowish/biegish possibly with a black tracer line. As it appears to have been cut, can someone tell me where it goes?
P.S. The engine ran great while in the Bronco so I know its a good engine/coil/distributor.
Thanks much!!!
Rick
Instead of clicking REPLY >
Click EDIT when adding info please
Old Apr 21, 2003 | 12:08 AM
rleeds's Avatar
rleeds
Thanks again.
