REGEAR
Old Jan 23, 2012 | 04:14 PM
mudbogger93's Avatar
mudbogger93
REGEAR
alright im gonna regear my truck to 4.88 and yukon gears would be good but the price is high so i was considering getting usa standard ring and pinions from rockauto but im not sure about the reliability and i was wondering about the whine any help would be appreciated.
Old Jan 23, 2012 | 04:18 PM
73FOMO's Avatar
73FOMO
Standard brand is usually decent quality stuff. Never used their gearsets. Were they that much cheaper than other well known brands?
Old Jan 23, 2012 | 04:32 PM
mudbogger93
well on bronco graveyard there is about 60 dollars difference between the yukon and the usa standard sets but on rock auto the usa standard is about 100 dollars cheaper than the yukon
im thinking about just going ahead with the usa standard on rockauto.com i was just wondering about the whine and the quality
Old Jan 23, 2012 | 05:21 PM
Kemicalburns's Avatar
Kemicalburns
do some shopping around man. the graveyard is spendy. if your having a shop do the setup why not have them price you the hardware?
Old Jan 23, 2012 | 06:17 PM
rla2005's Avatar
rla2005
Ring Pinion.com look at some of the notes about USA Standard ring and pinion sets.
Old Jan 23, 2012 | 08:29 PM
mudbogger93
ill be doing the gear swap myself. and are you talking about cause it says for keeping cost low and not recommended for quiet running vehicles.
my truck is lifted 10 inches on 36 tsl's so i really need to regear since it still has 3.08's and i was honestly wondering how usa standard holds up. i can get both 4.88 gear sets for about 350 dollars. this would not be a daily driver just weekend and stuff so wouldnt get too many miles
Old Jan 23, 2012 | 11:13 PM
GNR22's Avatar
GNR22
That's a gutless combo..the 3.08s and 36"s behind a 302 i mean. You're going to lose MPGs like you wouldnt even believe though. I would check out summit and Jegs for sure.
Old Jan 24, 2012 | 12:02 AM
mudbogger93
oh i know it sucks thats why im trying to regear i have the money to buy the stuff to do it i just aint sure about how well the usa standard ring and pinions will hold up
Old Jan 24, 2012 | 12:12 AM
GNR22's Avatar
GNR22
This is your daily driver right? I really wouldn't put anything bigger than 4.11s behind it honestly...
But if you really want to put 4.88s, I've heard good things about Usa Standard. My buddy has a 514 CI Stroker motor in a pulling truck that's pushing 600 horse and they lasted through that punishment.
Old Jan 24, 2012 | 12:13 AM
mudbogger93
im going to go ahead and order both sets of 4.88s
edit: this is not my daily driver and with the 36 inch tsl's and heavy steel wheels i figured 4.88's would be better but i dont know do you think that would be too much gear?? and i might be getting 39.5 tsl's soon
Old Jan 24, 2012 | 09:09 AM
GNR22's Avatar
GNR22
Oh well that changes things then. If you're going that big, by all means, put 4.88s on her. That's kind of overkill for just 36", but that should feel a lot better behind something that close to 40"s.
Old Jan 24, 2012 | 09:55 AM
Conanski's Avatar
Conanski
Probably not so much with a 5.0 under the hood. 4.88s and 36" tires is equavelent to 3.93 with the stock 29" tire..which isn't far off the ideal of a 3.73:1 final dive ratio. Strap 39's on it and you're down to about 3.6:1 which is a bit under geared for a small V8 like this.
Old Jan 24, 2012 | 10:06 AM
BRay09's Avatar
BRay09
I'd go with 5.13 or better. Especially for a 5.slow
Old Jan 24, 2012 | 11:16 AM
Kemicalburns
i agree with 5.13's. i currently run 4.88's with my 35" at's and if i went to any taller tire with more aggresive tread the grearing is crucial.
with my setup running the e4od i am just under 2500rpms at 70mph
Old Jan 24, 2012 | 01:23 PM
Edgethis's Avatar
Edgethis
I wouldn't be so worried about ring and pinion gear quality so much as half ton axles and drivelines with 36-40" tires......
