Need some help on this one!
Old Jan 23, 2012 | 10:46 AM
js139's Avatar
js139
Hey everyone. I need some help on this one. This morning I went out and started my truck and was warming it up. After about 10 min, I jump in and as soon as I touched the gas, it died. I know it can be a sensor, but my concern on this one is that now my dp tuner is not on now. Did I lose a computer? Any ideas?
Old Jan 23, 2012 | 11:10 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by js139
... Did I lose a computer? Any ideas?
You might try removing the keys from the ignition (and/or disconnecting the batteries), remove the DP chip and then see if the engine starts.
Old Jan 23, 2012 | 11:31 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
X2. It happened to me once the chip had some wires pinch.
Old Jan 23, 2012 | 11:42 AM
just another truck's Avatar
just another truck
Or even a loose conection to the DP switch..
Old Jan 23, 2012 | 11:53 AM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Did you bump the switcher by chance? Does the switch lite up?
Make sure it is not in pos. 0.
https://www.dp-tuner.com/media/pdf/F..._Operation.pdf
Have you checked you oil pressure? How cold was it? Gelled fuel? Dead or weak batteries? The chip/switcher must see 12v to work.
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Jan 23, 2012 | 12:31 PM
1996pwrstrk's Avatar
1996pwrstrk
Check fuse #30 if your fuel bowl heater shorted it would blow the fuse which is also for your power to the PCM .If so unplug the heater and replace the fuse.
Old Jan 23, 2012 | 12:40 PM
just another truck
This only happens when you are 150 miles from anyone, and no tools.. just a cell phone and a list of friends to call..flash backs..
Old Jan 23, 2012 | 12:43 PM
js139's Avatar
js139
Thanks for all of the great ideas. I will try to pull the chip tonight and see if that is the issue. The DP tuner was lighting up just fine until it died (i had it in stock) and now the switch is completly dead. Another thing I noticed is now the "wait to start" light isn't coming on either.
I am actually hoping for a fuse, so I will check this tonight as well. As for temperature, it was probably 40 out, so I don't gelled fuel is the issue as the DP would still light up if that was the issue. The batteries might be a bit low as the truck has been a little sluggish to start recently. I will check that out tonight. As for the battery thing, if the batteries are weak and the DP doesn't power up, will that stop the truck from running?
The thing that scared me was the the truck was running for 10 minutes and as soon as I started moving, it completely died and doesn't fire when I turn it over. Sounds like it might be a loose connection with the DP, but would that stop it from running like that?
This definitely was not the way I wanted to start the week out. Hopefully it is an easy fix. Thanks everyone for chiming in. I appreicate it!
Old Jan 23, 2012 | 12:49 PM
js139's Avatar
js139
I guess it could have been worse. At least I was still in my driveway!
Old Jan 23, 2012 | 12:51 PM
just another truck
It sounds like you lost the fuse. If thats the case, unplug the fuel bowl heater before you replace the fuse. You do not need this, trust me..
Old Jan 23, 2012 | 03:58 PM
BillyBob69's Avatar
BillyBob69
What Pat said^^^^
Sounds like the 30AMP fuse that not only controls the fuel bowl heater but the PCM as well.
With no WTS light and the DP Tuner not lighting up at all seems to me like no power to the PCM.
Unplug the fuel bowl heater harness, replace the fuse and try again.
Old Jan 23, 2012 | 04:00 PM
ToMang07's Avatar
ToMang07
Originally Posted by BillyBob69
What Pat said^^^^
^Ditto.
Old Jan 23, 2012 | 04:03 PM
BillyBob69's Avatar
BillyBob69
What Pat said^^^^
Old Jan 23, 2012 | 11:51 PM
js139's Avatar
js139
Thanks to everyone. The culprit was a bad fuse. A lot cheaper than a new computer that I thought it was. Thanks again for the help and information.
Old Jan 24, 2012 | 12:01 AM
BigAlsPSD's Avatar
BigAlsPSD
Did you keep the Fuel Bowl heater disconnected? If not it will blow the fuse again likely.
