Try to seal where the bulb housing goes into the gauge with a little silicone. On any Autometer gauge I had that was the only opening. The rest should be sealed. Make sure to do it when they are nice and dry. Either take them out and bring inside to dry out or run the defroster with the heat on for about 20 minutes. Should do the trick.
