engine noise
Old Apr 20, 2003 | 08:24 PM
dougas's Avatar
dougas
Cool engine noise
1990 4.0
It seems my sweet van has a lifter problem. I think. It seems to tick only at certain times and it seems to be getting louder. Goes tick, tick, tick ... stops and then does it again all the time. [COLOR=purple] Anyone else have this probem?
Old Apr 21, 2003 | 12:41 AM
mrshorty's Avatar
mrshorty
engine noise
What "certain times" does it tick? Would you classify the tick as lifter noise or spark knock/ping/detonation? Spark knock is fairly common on the 4.0 OHV and can usually be easily fixed. But, lifter noise is also a good candidate on an engine that old. Different causes and different fixes for either one, so need to be fairly certain of whether it's spark knock or valve noise.
Old Apr 22, 2003 | 06:40 PM
dougas's Avatar
dougas
engine noise
what is the difference between a spark knock and a lifter knock it seems to tick in a pattern the noise is coming from the passenger side only ticks twice then stop then ticks again. it seems to only tick when certain cylinders fire thanks 1 2 3 tick tick 6 i hope this helps
Old Apr 23, 2003 | 10:24 AM
mrshorty's Avatar
mrshorty
engine noise
ping or spark knock is usually described as the sound of marbles rolling in the engine. Something similar to the sound made by old VW beetle engines. It also usually occurs only under load (acceleration, climbing hills, etc).
lifter noise is a metal on metal clatter that would appear to come from the valve covers.
Old May 8, 2003 | 10:02 AM
okiebronco's Avatar
okiebronco
engine noise
you sure it isnt a plug wire that has gone bad? ive seen them where they arc at times and then stop for a bit and start arcing again. that could cause a pop noise that is easily mistaken for a tick from a lifter
Old May 8, 2003 | 02:09 PM
millertime300's Avatar
millertime300
engine noise
Run a little heavier oil you will be fine I spark knock will only happen while the motor is under load, everytime. A lifter will come and go with no real rym or reason.
MDSuperDuty
Modular V10 (6.8l)
Aug 1, 2019 06:54 PM
fordboy97
May 25, 2015 06:20 PM
F350Man79
Jul 28, 2014 07:59 PM
deserttruck
Modular V8 (4.6L, 5.4L)
Dec 30, 2004 03:36 PM
dhashberger
Aug 30, 2004 01:57 PM
