Considering converting to manual steering
Old Jan 24, 2012 | 07:08 AM
Lunar Ranger's Avatar
Lunar Ranger
Ok, you guys convinced me. I will start gathering parts to do the Ford PS swap and get a steering box ordered from Redhead. Thanks for taking the time to respond!
Old Jan 24, 2012 | 09:34 PM
Ford_Six's Avatar
Ford_Six
Originally Posted by lightninquick
I just changed mine today. It's Alot shorter, maybe 6-8"? I can measure it if it is important to you
Are you sure we're talking about the same thing? I had to cut my manual column down 2" when converting to power steering, and have always heard that the Ford PS column was the shortest.
The distance between the firewall and the steering box was shorter for the Bendix box by about 6-8"? On a 67-72 truck? (IIRC that would put the rag joint pretty much up against the firewall).
Old Jan 25, 2012 | 11:07 PM
jhooch's Avatar
jhooch
I put the Bendix box in my '66 and without modifying the column, the steering wheel set just over an inch from the column (unsightly gap). To fix it, I used the steering shaft from a 68 F100 with factory Bendix power steering. I simply inserted the 68 shaft into my 66 column. The Ford box uses an even shorter shaft. I actually wished I had gone to the Ford box after hearing all the horror stories on the Bendix box. I have a couple columns, and some 70's steering shafts. I may mock one up when I get time and see if you can put a 70's shaft into an early column.
Old Jan 25, 2012 | 11:09 PM
jhooch's Avatar
jhooch
I'm not sure if Redhead sells boxes (they are a remanufacturer), they may have some rebuilds ready to go but will probably charge you a core. I'm getting ready to send them the steering gear out of my 73 Bronco.
Old Jan 26, 2012 | 06:59 AM
Lunar Ranger
They have some boxes in stock, the Ford gear being one of them. They will charge me a core, so I'll just get a box from the junkyard to send them. He quoted me $219 plus core, plus shipping. That seems really reasonable to me. He charge $450 + to rebuild a Bendix. That makes this choice a no-brainer IMO
A&P_Tech
Feb 12, 2018 12:04 PM
ghart
Aug 9, 2016 11:48 PM
427 fordman
92
Jun 1, 2013 11:35 PM
mattthegreat
Jun 2, 2012 09:46 AM
twkisner
May 27, 2003 11:37 PM
