Clutch linkage squeak?
Old Jan 22, 2012 | 09:17 AM
Major Marvin's Avatar
Major Marvin
Most times I press down on the clutch I hear a squeak first thing. After driving a while it seems to go away. I climbed under the truck yesterday and located the linkage unless it's called something else. There is a black boot there as well. I just want to get this right as far as lubing it goes.
Also, when truck is cold I notice a shutter when getting into gear. Again, when the truck warms up a bit the shudder goes away. I was told that the clutch was replaced at 130,000 miles and I now have 180,000 miles on the clock.
Old Jan 22, 2012 | 10:30 AM
madpogue's Avatar
madpogue
You were probably looking at the fork, which is pushed by the hydraulic slave pushrod. Don't try to lube it there. If the squeak is coming from the fork, it's from inside the tranny, where the throwout bearing is. But the squeak is probably coming from the cab, from the pedal assembly.
When the clutch was done, did they replace the dual-mass flywheel with a single-mass?
Old Jan 22, 2012 | 10:54 AM
Major Marvin
I'm guessing they did whatever was closest to stock at the time. I bought the truck at about 165,000 miles.
palsims
Sep 20, 2015 09:37 AM
Fordbronco69
Dec 13, 2012 07:54 PM
charlessocccer
34
Dec 15, 2010 03:17 PM
BigBadPowerstrok
Aug 18, 2007 04:22 PM
whiteyfordzx5
15
Jun 28, 2007 10:58 AM
