Exhaust?
Old Jan 22, 2012 | 12:11 AM
Lownslowsrt's Avatar
Lownslowsrt
Exhaust?
ok new guy here, i know these motors normally have weak studs and gaskets which is why i wont be installing a programmer until i do studs/head gaskets, so my ? really is would jus a intake and exhaust cause problems for my truck
truck already has a intake from the previous owner
truck is jus shy of 169k miles, i have personally replaced the IPR/FICM/Injectors
and if it wont hurt what are some good systems that wont kill the pocket but sound amazing
Old Jan 22, 2012 | 06:07 AM
04PSDCREW4X4's Avatar
04PSDCREW4X4
Found mine on eBay. Turbo back 4" no cat no muff. Off road use only(wink wink). I paid 249.00 total shipping included. It was make offer I found three different places that said make offer and told them what the other guys would sell it for and got a good price.
Old Jan 22, 2012 | 06:14 AM
04PSDCREW4X4
Sorry forgot to say it was a MBPR EXHAUST
Old Jan 22, 2012 | 09:00 AM
Lownslowsrt
Do you think a intake/exhaust will cause any problems? I have heard those and I like them
Old Jan 22, 2012 | 09:16 AM
69cj's Avatar
69cj
The stock intake is good for 500 hp and no a/m filters better in its operating range. Leave the intake alone. This is not an op. It's been proven.
Old Jan 22, 2012 | 09:34 AM
olfordsnstone's Avatar
olfordsnstone
As I understand it, exhaust wont cause any problems. Unless you consider a possible slight increase in mileage and horsepower a problem.
On another note, I have had experience with an SCT tuner with custom tunes from Matt@gearheads. Matt ensures that the tunes he writes (for non-studded use) are safe with non-studded engines. He does suggest to go with a larger exhaust for EGT however. If you were to do this, gauges are a VERY good idea too.
The unlimited tow setting Matt writes is pretty much the same as the Ford Stock tow tune, just turns off a CEL that you might want to go away:-. His SRL tune has much better peddle response and is very fun to drive (and also turned off that pesky CEL I referred to above). I have had no problems running with these tunes non-studded... Knock on wood.
Matt at Gearhead and Eric at Inovative have some performance tunes that are CRAZY fun too. But for those you would definitely need to stud your truck. If you decide to go with an SCT tuner and custom tunes, you would need to advise of what they are for and they can be written milder, but a BIG improvement over stock. JMO
Back to exhaust, don't be afraid of exhaust. The only thing is, if you want to remain within your state's smog requirements, you will need to go with cat back, vise turbo back. To pass smog you would need to have the cat in place, although there is an item I have heard of called a "Test Tube", which you bolt in, in place of the cat and can put it back when needed... Don't know much about these.
Of course, if you choose to maintain compliance with smog laws, in that case a tuner would be out of the question too...
The stock air intake is great stuff and good to go, unless you go with CRAZY performance mods. For yours, stock is good.
Old Jan 22, 2012 | 11:31 AM
Lownslowsrt
I dont have the stock intake, a previous owner installed a AFE
Old Jan 22, 2012 | 11:34 AM
Lownslowsrt
Some awesome info, thanks, and also im in MS and they dont check for smog lol, ive been looking at 4in turbo back from MBRP and silverline both sound pretty amazing
BrokeLoser
Oct 31, 2016 06:46 PM
Hotpocket
Exhaust Systems
May 23, 2011 09:33 AM
oughtsixbigred
Nov 8, 2010 10:05 PM
350on44s
13
Jan 31, 2010 12:24 PM
SILVER STROKE
Jul 9, 2007 10:43 PM
