Brakes
Old Jan 21, 2012 | 09:31 PM
Bootzz711's Avatar
Bootzz711
Brakes
92 f250 4x4
Barely any brakes
If I pump my pedal it will get had then let sit and nothing again
Not losing fluid and have bled the $(-)it out of them
Thinking a booster or master cylinder?????
Any input?
Thinking bout just changing both
The booster looks in bad shape on the outside
Old Jan 21, 2012 | 09:37 PM
SCRebel's Avatar
SCRebel
I think master cylinder. Cause if it was the booster the pedal would be hard to mash all the time, like non-powered brakes.
danr1's Avatar
danr1
Sounds like the master, easy test remove the lines from it.
Plug the line ports, pedal should be solid.
Old Jan 22, 2012 | 10:34 PM
Bootzz711's Avatar
Bootzz711
Pedal should be solid as meaning it's working or it's broke?????
Old Jan 22, 2012 | 11:02 PM
88n94's Avatar
88n94
Are your rear brake shoes adjusted up?
Old Jan 22, 2012 | 11:08 PM
Midnite1987's Avatar
Midnite1987
If its solid it's working. If it goes Down its not. If it goes down then something is passing where it shouldn't be
Old Jan 22, 2012 | 11:15 PM
KC92F150's Avatar
KC92F150
Do you have a diesel or gas engine?
If diesel it may be the vacuum pump.
Old Jan 23, 2012 | 05:02 AM
tjc transport's Avatar
tjc transport
i ain't rite
bad vacuum pump will give a had pedal, not soft.
Old Jan 23, 2012 | 08:46 AM
Bootzz711's Avatar
Bootzz711
It's diesel and yes my rear pads are adjusted
Old Jan 24, 2012 | 08:57 PM
Bootzz711's Avatar
Bootzz711
Ok so my pads were adjusted but my pads are cooked and my rear wheel cylinders ate busted
Got pads and cylinders and as well I got a hardware kit
When I get a Lil more cash I'll change my front rotors calibers and my master
Old Jan 24, 2012 | 09:17 PM
blkF250HD's Avatar
blkF250HD
Easy way to test the master is to get some line clamps and clamp the hoses off. One going to each front wheel, and one going to the rear axle. Don't need to go crazy tightening down the clamps here either. Pedal should be hard. If not, master is bad or you have a leak. Remove one of the clamps to isolate the pressure loss. Sometimes if you look closely at the back of the master where it bolts to the booster you will see brake fluid running down the booster. This happens when the seal in the master begins to leak. Make sure the master is actually bad before you replace it. Also, if you do replace it get a new one, not a reman. It'll cost more, but they usually come with a reservoir and are of better quality. I've seen three bad Cardone (Car Don't) reman masters in a row. If I am handed one at work to install I give it back and ask for a new one unless the customer specifies a reman.
Leaking wheel cylinders will definitely cause a low/soft pedal, as they aren't holding pressure any longer. Verify that the front caliper pistons retract the way they should and there's no leakage from the seals. No sense in replacing a working part; I've seen many rebuilt calipers fail due to poor materials or just being "cheap". Usually "Re-manufactured In Mexico" is on the box.
Old Jan 24, 2012 | 10:03 PM
Bootzz711's Avatar
Bootzz711
Well that's where my headache is
Is that I'm not losing fluid
But I'm gettin lucky and i have someone who offered to pay to have it all redone and have new parts if I haul his horses for him and all he has to pay is the diesel
So I plan on changing it all
Christof13T
Nov 24, 2012 06:39 PM
vtjvt
Sep 30, 2012 04:06 PM
rch
Bronco II
Mar 16, 2005 09:44 PM
mxer201
Aug 20, 2002 09:35 PM
72RangerXLT
Apr 29, 2002 08:12 PM
