What is Torgue
Old Jan 22, 2012 | 10:26 AM
  #31
brcrk's Avatar
brcrk
Originally Posted by SCRebel
I wonder if some of that has to do with the older engines being push rod engines, and the newer engines having overhead cams.
My 89 F150 with a 351w, has a quicker response and low end power than my dad's 07 F150 with a 5.4.
Never thought about that...Hmm
Old Jan 22, 2012 | 10:31 AM
  #32
brcrk's Avatar
brcrk
Originally Posted by 93 mix 'n match
almost all new cars have a factory equipped "dead-pedal". they have electronically controlled throttle bodies, and they dont slap open when you mash it. they gradually open, and most dont open 100% until around 4krpm. this also means slower throttle response.
I hate that "fly-by-wire" stuff. You open the pedal and the computer asks itself "is this really what he wants to do?" Stupid!! This is exactly why Toyota got in trouble over there mishaps a few years ago.....with them claiming "well the operator got the pedal under the floor mat"....and to this day they they haven't owned up to their "fly-by-wire" computer was at fault.
Old Jan 22, 2012 | 10:43 AM
  #33
brcrk's Avatar
brcrk
Originally Posted by Diesel_Brad
Exactly. More that ANY 60s muscle car
But!! You cant see the forest for the trees...LOL. Yes..it does...BUT how many people of this generation have ridden in one? How many have expeirnced that kind of power? In my generation everyone had access to someone that had that kind of power.
BTW...(I am no Dodge man so bear with me if I am a little off) a 70 Cuda had a 426 cu Hemi which was "published" to have 425 hp / 490 torgue...probably more like 500/600......and I will promise you that if you sit in the Hemi and the Ford and you WILL know the difference!!!
Old Jan 22, 2012 | 11:48 AM
  #34
SCRebel's Avatar
SCRebel
If I had to buy a new "muscle car" it would be the Mustang GT, or Mustang Boss 302.
The 2012 Mustang specs for the 5.0 liter Coyote engine, pumps out 412 horsepower at 6,500 rpm and 377 pounds of torque at 4,250 rpm , while the Boss 302 models receive an upgrade to 444 horsepower and 380 pounds of torque.
However its still got more hp than torque. But (I think) impressive for a 302.
The 2013 Shelby GT 500 has 650 hp and 600 fpt. Then I know you can have it sent to Shelby himself, and he will sign the dash and sun visor, and slap a bigger super charger on it, to get even more power. but that's big bucks.
Old Jan 22, 2012 | 11:52 AM
  #35
brcrk's Avatar
brcrk
yep
Old Jan 22, 2012 | 02:35 PM
  #36
wicat3's Avatar
wicat3
If you could find a dodge around anymore they would be just like a ford and a chevy but no mater what they can do and how impressive they are id still rather have a ford.
Old Jan 22, 2012 | 02:42 PM
  #37
danr1's Avatar
danr1
"Horse power" is figure from "Torque",
Torque, HP, Speed
Old Jan 22, 2012 | 03:40 PM
  #38
toby tough's Avatar
toby tough
Back in the day a freind of mine had a 327 Vega.The cops in Council Bluffs didn't like us very much,but it had that neck snappin' seat smashin' throttle response we all know and love.Had a 74 FLH I built up that was good on torque too.Zoomazoom.Now iv'e settled for a minivan and my 92 F150.Oh well.
Old Jan 22, 2012 | 03:52 PM
  #39
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Detroit built a lot of "torque monsters" in the late 50s through 70s, most of these engines were in luxury cars, Cadillacs, Lincolns, etc. Buick actually designated their engines in the 60s by torque, the 401 was a "Wildcat 445" the 425 was a "Wildcat 465". Buick's nail head was a real torquey engine due to it's small ports and high lift cam, it needed to be with a Dynaflow! The original 430 Lincolns were 375hp and 490ft-lbs rated. All of these engines were designed to drag 3 tons of steel away from a stoplight with a long legged rear end gear so they actually got pretty decent gas mileage considering 1 - over 400ci, 2 - no lock up torque converters, and 3 - breaker points and carburetors. Chrysler's original hemi, the 392ci version was a pretty good torque engine too.
  #40
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by brcrk
yep
WHat are you taking about?
1st, you are saying there is nothing with torque these days.
Now you are saying that there is not enough vehicle with torque.
You have to keep things in perspective. Muscle care were the thing to have in the 60s. Today, not so much.And the REAL muscle cars of today make MORE HP AND torque than the ones from the 60s.
But DIESEL trucks are the thing to have and they make MORE HP and MORE torque that the 60s muscle cars, get 15-20MPG doing it and can tow 4 muscle cars. Just because the muscle car era died doesnt mean torque has
Old Jan 22, 2012 | 04:24 PM
  #41
F-250 WARHORSE's Avatar
F-250 WARHORSE
Exactly. 2000+ft/lb
and 600+hp
Not to mention off idle as well. If you want to see torque do that!!
  #42
Slip ford man's Avatar
Slip ford man
There is torque today but it is nothing like the flat torque curves of those engine's produced from the early 60's through the early 70's, they were insane. They were the reason that we have mandatory car insurance today. There was no insurence needed by law back then till these engines appeared, and people were killing themeselves and others with those heavy cars.
Take the 409 for example the combustion chamber was in the upper part of the cylinder, not the head, the head having only tiny recesses for the valves. They did this by combining the use of a cylinder head deck that was not perpendicular to the bore with a crowned piston, as it aproched tdc, the angle of the crown combined with that of the head deck to form a wedge shaped combustion chamber with a pronounced quench. The spark plug protruded vertically into this chamber, which tended to cause a rapidly moving flame front during combustion.
torque developed at low and high engine speeds, resulting in an engine with a broad torque curve, its just not the same with todays engines, and you would need to feel them to understand I think.
Old Jan 22, 2012 | 04:36 PM
  #43
Diesel_Brad
I have driven plenty of Muscle cars, 429s, 454s, 426 hemis. And a new Mustang or camaro will blow their doors in. A 8k pickup will keep up with them too
I dont really think you can get a much flatter torque curve than a diesel
Old Jan 22, 2012 | 04:48 PM
  #44
Slip ford man
Okay then, but only hookers like to climb up into those cab's
Old Jan 22, 2012 | 04:49 PM
  #45
rickpilgrim's Avatar
rickpilgrim
Toque is what you see when that" little" Estes semi truck with day cab and single rear axle takes off with a load of cement blocks and twists the frame and yanks the front fender up!
