I'm no help, but since I have this on my to do list too, I am subscribing. What did the filter and base cost you? Make us up a materials list and show the costs if you could. I've been eying the dieselsite.com kit, but I am sure that you can put together your own kit a lot more economically.
I think I'm awake now, how's this? Over the top is my water injection hose, on the right side is the line for a coolant gauge and behind it are my steel braided electric fuel lines.
Thanks Glenn. Where did you tie into? On the guzzles site, the inlet comes from the side of the water pump. It looks like Rodney tied into the heater lines. Just trying to get some ideas.
Also, the Napa vague instructions talked about putting in shutoff valves for the inlet and outlet for less of a mess when changing filters. Anyone do this or you just wait till the system isn't under pressure to change?
