Ford E4OD Problems
Old Jan 20, 2012 | 02:06 PM
converteddodgeguy's Avatar
converteddodgeguy
Ford E4OD Problems
Ok so ive had this problem since i bought the truck and has never realy caused any damage anywhere except in the rain and snow it makes it break loose much easier. i bought the truck at 90,000 and im at 217000 now. I just recently added a programer and bored it out and now im concernd the extra power will cause catastrophic failure, i found this which accuratly describes it any ideas as to what the problem is? my 92 f-250 felt this way when the driveshaft was getting loose but no such problem on this one.
<TABLE style="BORDER-RIGHT: black 1px solid; BORDER-TOP: black 1px solid; BORDER-LEFT: black 1px solid; BORDER-BOTTOM: black 1px solid"><TBODY><TR><TD>TSB data for: 2004 FORD F-150</TD></TR><TR><TD>Bulletin Number: 04266</TD></TR><TR><TD>Sequence Number: 10014275</TD></TR><TR><TD>Date: 20050101</TD></TR><TR><TD>Component Name: 105000 POWER TRAINRIVELINE</TD></TR><TR><TD>Make: FORD</TD></TR><TR><TD>Model: F-150</TD></TR><TR><TD>Year: 2004</TD></TR><TR><TD>Summary:</TD></TR><TR><TD>A DRIVELINE CLUNK OR BUMP WHEN STARTING FROM A STOP. *TT</TD></TR></TBODY></TABLE>
Old Jan 20, 2012 | 03:28 PM
Lazy K's Avatar
Lazy K
2004 - 2008 F150 - Ford Truck Enthusiasts Forums Here is a link to the page if you do have a `04 F150. If it is an `04 you do not have an E4OD.
However check the driveshaft universal joints, if 4x4 check that the front driveshaft slip joint is free and check your motor mounts.
Old Jan 20, 2012 | 06:16 PM
LxMan1's Avatar
LxMan1
Moved to correct forum.
Old Jan 30, 2012 | 07:57 AM
converteddodgeguy
It is a 2WD but i have checked all the universals their is no slop but thanks for the help i didnt even consider the mounts, il check those tonite and get back with you.
James97gt
16
Aug 31, 2016 06:10 PM
deljac
15
Jan 25, 2016 06:29 AM
nickmav70
Jul 7, 2010 09:43 PM
nyironbiker
2004 - 2008 F150
Jan 12, 2006 07:31 PM
