OK. New Development
Old Jan 22, 2012 | 02:32 PM
zhilton's Avatar
zhilton
Originally Posted by m-chan68
Cylinder #2 is the cylinder at the very front of the engine on the DRIVER side. The cylinders on the passenger side of the engine are numbered 1, 3, 5 and 7. The driver side are numbered 2, 4, 6 and 8.
Your absolutely right, had a case of cranium inverted rectum on my hands. Thank you for catching my goof
Old Jan 22, 2012 | 04:34 PM
mblanken881's Avatar
mblanken881
Ran AE while driving to the airport today. Exhaust back pressure absolute was always 14-18 higher than exhaust back pressure desired. Exhaust back pressure absolute was running the same as SG II (ran SG II before running AE, I know not safe to switch while driving, but OH WELL). Also, exhaust back pressure on AE ran at ~2.5 V while at cruising speed.
FYI - These tests were ran while at 2000 RPMs going down the interstate.
Old Jan 22, 2012 | 04:44 PM
BLADE35's Avatar
BLADE35
so actual EBP was 14-18 PSI higher than desired EBP
Thats A BIG Diffrence if Im understanding it right thats Huge Diff
Old Jan 27, 2012 | 10:22 PM
mblanken881
Replaced the oil pressure switch tonight. I noticed while taking apart the intake that EVERY clamp was loose. So loose that I could spin the screws with my fingers. Even the one at the turbo was loose. I really don't know how it hadn't came apart.
Anyhow, changed the oil pressure switch and reinstalled the intake making sure to tighten all the clamps. Truck seemed to run a lot better. Turbo seemed to whistle like it used to and seemed to accelerate and run much smoother. Would the loose clamps cause the shuddering issues I was having?
Old Jan 27, 2012 | 10:23 PM
mblanken881
Yeah, seemed BIG to me too. The EBP was in absolute though. Does that mean I should subtract atmospheric pressure from it's reading?
Old Jan 28, 2012 | 06:33 AM
npccpartsman's Avatar
npccpartsman
I guess EBP desired is something new for me. I don't remember seeing that on my previous version of AE but then I wouldn't have looked for it either. EBP, MAP, and BARO should be checked at KOEO and be within .5 psi of each other. EBP running is going to vary with boost. I guess EBP desired is something the PCM is trying to control to maintain a particular boost level.
akorcovelos
May 10, 2020 12:45 PM
Viperfoxbat
Oct 12, 2015 02:22 PM
quality1construction
Aug 14, 2011 07:59 PM
patshea814
Nov 24, 2010 01:26 AM
eficat
Nov 30, 2005 11:46 AM
