Sponsored by: Auxito
Replacing Heater Hoses Up Under Firewall
Old Apr 20, 2003 | 02:55 PM
samaustintx's Avatar
samaustintx
I need to replace a busted heater hose under the cowling next to the engine firewall....one end has the regular clamp to take off the hose, the other end doesn't. How does the other end of the hose near the firewall come off? Nothing underneath hood seems straightforward anymore.....
Old May 16, 2016 | 01:42 AM
GadgetGuy22's Avatar
GadgetGuy22
bump........
Old May 16, 2016 | 10:11 AM
Sam I Am's Avatar
Sam I Am
The original heater hose has a clip on connector sort of like a fuel hose fitting on the core end. If you look up the hose on O'Reilly Auto Parts store site it will show a picture of that end of the hose. Or visit your local parts store and look at one.
Using the specific heater hose removal tool, or a pair of long needle nose pliers, push the clip @ the holes in the sides toward the heater core and pull off the hose.
There are several Youtube videos that show how to do it.
The fittings are available from Dorman and can be replaced with bulk hose of the correct size and standard hose clamps.
The fitting has an O-ring to seal against the heater core nipple. By the time the O-ring leaks, the hose should be replaced also.
Old May 16, 2016 | 12:29 PM
GadgetGuy22
Ok. Thanks for the info Sam I am.
diesel 04 X
Dec 1, 2024 10:24 PM
rk40977
Oct 6, 2017 10:36 AM
SoCalAngler
Sep 18, 2017 05:26 AM
Gary Lewis
Sep 22, 2016 09:13 AM
E350 Van
Jul 10, 2016 12:15 PM
