Extreme delta
Old Jan 18, 2012 | 07:08 PM
JonArmy's Avatar
JonArmy
Extreme delta
Well today drove to the beach and back in one day (12 hr driving), I was unloaded both ways except the second passenger on the return trip.
Keeping a eye on my SGII I was watching EOT/fWT/ICP/FMP. Well I looked and I saw a spread of 24* at 70mph, 2000 rpm, ICP running between low 1400 to high 1370, FMP was running 48.0 to 47.5.
Pictures by JonArmy - Photobucket
When I got to slower than 65 mph, I would see the spread close in. I watched both ways and I bairly saw the fWT get to 190 and if it did it would last about 1 to 2 minutes.
Well doing my search through previous threads it looks like my oil cooler might be going bad, hopefully soon I can really drain/flush my coolent and install a coolent filter. What is everyones opinion on the spread and what I should take care of first.
Old Jan 18, 2012 | 07:32 PM
bismic's Avatar
bismic
Sounds like a plugging oil cooler.
Hopefully a flush will work for you - there is little to lose by trying it at this point (IMO).
Old Jan 18, 2012 | 07:37 PM
High Binder's Avatar
High Binder
You're delta will always be higher with higher RPMs but that high suggests a clogging oil cooler, like Mark said; try a flush but you're probably looking at a replacement. I've seen 20 on mine after an hour or so at 90MPH but I don't have to worry about an EGR so...
Old Jan 18, 2012 | 07:41 PM
BLADE35's Avatar
BLADE35
My truck had that 25* spread at all times didnt matter how fast or how far I drove everytime I would get to my destination I would have a 25* spread ECTvsEOT
when I pulled the oil cooler out and then cut it open It was compleatly Plugged
And also keep in mind that since it failed the test at 65mph steady speed its a Failed part period.
Even if you drive at slower speeds and the spread is not as far apart its just not getting worked to drive the spread up that High out But the oil cooler is still plugged and is starving the EGR Cooler of coolant
You can try to flush But honestly it may be to FAR Gone
maybe you saw this thread IDK just thought that I would post it, Some of these folks got there spread closer by flushing But I think Some Flushed for month and maybe 2. I just think that there is a Point where you cut your Losses and Dig in and change the Oil cooler, the coolant veins are so small its hard to flush them out once there to far gone but check it out
SOME GREAT IDEAS ON OIL COOLER BACKFLUSH
https://www.ford-trucks.com/forums/1...ch-advice.html
joejackF250
May 16, 2018 10:15 AM
jfirstford
Jun 14, 2012 03:47 PM
jl4407
Apr 3, 2012 03:29 AM
JonArmy
Oct 27, 2011 02:36 PM
mottrocks
Jun 10, 2010 07:38 PM
