Lower front fender extensions
Old 01-18-2012, 06:02 PM
Don Rocco's Avatar
Don Rocco
Don Rocco is offline
I just bought these fender extensions off ebay really decent! The problem is they are different from the ones i have.They said 51-52,i thought they were the same.Mine are kind of square by the wheel well,these kinda come to a point when they meet the wheel well.I looked all over at different pics and they all look like mine,,anyway did they make different ones for 51 and for 52..needless to say these are not going to work.to bad cuz i thought i scored,should have paid more attention!
Old 01-18-2012, 06:08 PM
critterf1's Avatar
critterf1
critterf1 is offline
Pictures might help.
Old 01-18-2012, 07:09 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
Are you talking about the lower fender or the lower section of the upper fenders where they meet at the running boards?
The lower section of the upper fenders (at the running board) remained the same design from 48-52. The front of the fenders and the lower fenders themselves differed between 48-50 and 51-52 design group years.
Old 01-18-2012, 07:23 PM
Don Rocco's Avatar
Don Rocco
Im trying to upload a pic,dont know how..no its where the extension butts up to the main fender and completes the wheel opening.if that makes sense?
Old 01-18-2012, 07:28 PM
51PanelMan's Avatar
51PanelMan
You're likely talking about the patch panel that goes on the upper (main) fender at the running board.
You can email me the pictures at modelking2000 at hotmail dot com.
Old 01-18-2012, 07:36 PM
Don Rocco's Avatar
Don Rocco
Its the front section of the fender that connects to the lower valance, not the rear of the the front section that connects to the running board
Old 01-18-2012, 07:46 PM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
Don there are several threads on loading pictures, but the instructions that helped me the most are in the "faq" button on the blue line towards the top of the page, there are a lot of how tos on drop down menues. Very helpfull start with general forum usage after you it Faq, you will see what i mean
Old 01-18-2012, 07:56 PM
51PanelMan's Avatar
51PanelMan
Just trying to get the terminology down...
The fender is made of two parts, an upper fender (the larger main piece) and the lower fender (smaller piece). The two bolt together to complete the assembly and the upper fender bolts to the running board, while the lower fender bolts to the lower valance.
EDIT: Received the picture and in process of uploading.
topmoo's Avatar
topmoo
topmoo is offline
And, you have to make sure your pictures are not too big. It won't tell you that they are too big, it just says that there is a problem. Check the size against the size limit listed. It took me months to figure it out...
Old 01-18-2012, 08:00 PM
51PanelMan's Avatar
51PanelMan
Here's the picture. The original fender on the left is from a 51-52 F2-F6 truck. The reproduction/replacement fender on the right is from a 51-52 F1. The difference is in the wheel opening. F2-F6 fenders had a larger wheel opening to accomodate for larger wheels/tires. No one to my knowledge reproduces F2-F6 fenders or patch panels.
Old 01-18-2012, 08:09 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
Sounds like you got the lowers for an F-2 to F-6. Truck.
Old 01-19-2012, 06:03 PM
Don Rocco's Avatar
Don Rocco
Thank you guys so much..i guess ill pay more attention.I should of figured something wasnt right when no one else was bidding on them LOL!
Old 01-19-2012, 06:14 PM
Don Rocco's Avatar
Don Rocco
The fenders i need are the 51 52 F1.. not the F6 ones.The ones i bought off ebay are the rusty color one F2 F6,the other one is fiberglass from Bebops,but when i saw the metal ones i figured i get them instead,but as you all can see they are the wrong ones ,so im back to square one. I really wanted the steel but i guess ill have keep looking or use the fiberglass..ohwell
49willard
13
02-12-2020 08:01 PM
arrowheadfred
12-14-2010 05:59 PM
jlang
09-29-2009 01:14 AM
51dueller
05-18-2006 12:19 AM
Quick Reply: Lower front fender extensions
