Please Help CEL with no power missing
Old Jan 18, 2012 | 04:37 PM
joshua1514's Avatar
joshua1514
I have a 95 f350 7.3l spd. While driving today the check engine light would come on itermitanly and the truck would loose almost all power for a few secs the return to normal, later on in the day cel came on permanetly and truck has extemely low power runs rough. No smoke. Please help thanks
Old Jan 18, 2012 | 04:57 PM
DIYMechanic's Avatar
DIYMechanic
Unless you want to just throw parts at it you need to get the codes read. The parts store code readers won't do it, it has to be a good quality reader to "speak psd". The only thing I can think of that would be a cheap attempt would be to change the CPS. As always, get one from Ford or International.
Old Jan 18, 2012 | 05:20 PM
joshua1514's Avatar
joshua1514
after looking at it now that i limped it home it is only runing on 4 cylinders (passenger side) however when I disconnet the rear driver side valve cover connctor (turbo inlet) the cel goes off and the engine runs on 6 cylinder?????
Old Jan 18, 2012 | 05:49 PM
fordpride's Avatar
fordpride
Pull the valve cover and check the wires to the injectors
Old Jan 18, 2012 | 06:43 PM
joshua1514's Avatar
joshua1514
i pulled the valve cover and the connectors on the inside are melted on the edges pretty bad. What causes them to short, and do they sell replacements at standard auto parts stores or is it stealership only??? thanks
Old Jan 18, 2012 | 07:15 PM
F350-6's Avatar
F350-6
A loose plug can cause them to short. It's not too uncommon. Many of the local parts stores sell a replacement valve cover gasket and wiring made by Dorman. Several here have used those with success. You can also get them from an International truck dealer cheaper than the Ford house will sell it to you.
Old Jan 18, 2012 | 09:21 PM
fordpride's Avatar
fordpride
Bad glow plugs or bad connections to the glow plugs is the main reason they melt
Old Jan 19, 2012 | 07:02 AM
joshua1514's Avatar
joshua1514
Thanks for the replies, I will change the glowplugs on that side and replace the gasket,,,,,I just hope I didn't overheat the other side of the engine getting it home...... Just one of those weeks when everything is going wrong.. Thanks everybody.
Old Jan 19, 2012 | 09:53 AM
fordpride's Avatar
fordpride
I wouldn't drive it on six cylinders to far
Shattered
20
Jan 15, 2018 10:20 PM
jcahicks
Jan 26, 2012 06:50 PM
danimalmanimal
22
Oct 24, 2011 07:52 PM
rascal1
Aug 3, 2007 02:51 PM
Dukhunt22
13
Mar 22, 2006 11:06 PM
