fuel leak fixed
Old Jan 18, 2012 | 02:32 PM
jhobbs26's Avatar
jhobbs26
fuel leak fixed
I had a small fuel leak on the back side of the engine. After reading this site of all the possible causes i decided to buy all the o-rings needed from dieselOrings.com plus the fuel lines down in the valley.
I tore into the project monday around noon. It took me about 5 hours total to rebuild the fuel bowl, replace the fuel pump, and the 2 o-rings on the fuel lines in the back of the heads.
Hardest part of the project was getting the o-rings out of the fittings and getting those fittings threaded back on.
I might of got lucky with the banjo bolt, it only took me about 10 minutes of trying to get it started before i finally got it.
The FPR screens were pretty nasty, which i suspected would be.
After going through it all, i suspect the leak was from the fuel pump all along.
Next up is GPR and probably glow plugs as this beast bellows white smoke on cold start ups for about a minute or less.
Old Jan 18, 2012 | 03:04 PM
BIGRED 7.3L's Avatar
BIGRED 7.3L
It probably was the pump. Nice Job!
Old Jan 18, 2012 | 04:11 PM
Copedawg's Avatar
Copedawg
Congrats on the fuel pump!
If I may make a suggestion, if you are going to do the GP's I would also do the injector o-rings at the same time.
Glad your truck is no longer leaking fuel.
See you around!
Old Jan 18, 2012 | 05:45 PM
jhobbs26's Avatar
jhobbs26
See you around!
I didnt think about doing anything to the injectors while i was in there. Makes sense tho. Are there any cheap mods that can be done to the injectors while i had them out?
Old Jan 19, 2012 | 05:09 AM
Copedawg's Avatar
Copedawg
I don't know of any. Maybe some one else will be able to guide you better.
Old Jan 19, 2012 | 05:36 AM
Copedawg's Avatar
Copedawg
Here is a link of my o-ring replacement: https://www.ford-trucks.com/forums/9...placement.html
There is a video on the 1st page that really helped me a lot along with everyone elses info. remember, do 1 at a time.
Old Jan 20, 2012 | 09:51 AM
jhobbs26's Avatar
jhobbs26
Thanks Copedawg
Jr.'s7.3
Dec 3, 2017 06:28 AM
imjwm
Jun 21, 2014 10:47 PM
dslpwr530
19
Feb 26, 2013 06:54 PM
97biostroke
Jan 6, 2011 03:51 PM
MarkSullivan
13
Oct 18, 2009 10:32 PM
