EOT and ECT Spread
Old Jan 18, 2012 | 07:03 AM
DevilDocTater's Avatar
DevilDocTater
Master of Disaster
EOT and ECT Spread
So here is my Manual Gauge spreads, are these acceptable? This is during normal driving on 50mph back roads that are hilly with lots of curves. Somtimes my SGII shows 180 ECT and 200 EOT, buy my gauges always seem more consistent. Any opinions?
Thanks!
Wade
Old Jan 18, 2012 | 07:21 AM
npccpartsman's Avatar
npccpartsman
The ECT/EOT spread spec. is taken at the factory sensor location. Analog sensor data would need to be read at those locations to have a direct correlation. If your ECT is only 180 by SGII then you need a thermostat.
Old Jan 18, 2012 | 07:29 AM
DevilDocTater
Master of Disaster
Yeah i just replaced the thermostat this summer, SGII ECT is between 180 and 188. And my analog sensors are very close to stock sensor location
Old Jan 18, 2012 | 08:54 AM
69cj's Avatar
69cj
Either close doesn't cut it or you still need a t-stat. Was the new one a Ford product?Hilly also doesn't cut it. You need to be on level grond with the engine totally heat saturated. 15 to 20 miles at high way speeds. If your on hills and curves the temps will be chasing each other.
Old Jan 18, 2012 | 08:32 PM
DevilDocTater
Master of Disaster
Yeah it was a brand new Ford T Stat with housing. I was even towing today and still had the same spreads. What temp are the t stats supposed to open?
Old Jan 18, 2012 | 09:57 PM
frankmako's Avatar
frankmako
ford t-stat should open at 190/192.
Old Jan 19, 2012 | 09:06 AM
69cj's Avatar
69cj
I normally run 194 to 204 depending on ambient temp, terrain and load. In the Sierras loaded I have hit 224 with zero puking. 12 mile 7% grade.
cgunning17
Jun 22, 2019 05:39 PM
Duct Tape Racing
Feb 4, 2018 06:22 PM
F-250 restorer
Feb 23, 2011 04:45 PM
ss150
Sep 1, 2007 11:14 PM
MarkA100
Modular V8 (4.6L, 5.4L)
Feb 20, 2005 11:14 AM
