9" swap...what gears avail?
I recently swapped to a C6 in my '85 F150 4x4. The 3.55 8.8 rear axle is close to crapping out, so I'm looking into swapping to a 9". I would like to go to a 3.08 or 3.00 ratio...but what would match that in my front axle? What ratios were offered in the TTB front axles? The worn out TOD manual I swapped from had overdrive so I'm looking for a way to reduce RPMs on the highway as well since I'm turning almost 3k at 65mph...the 300 sounds a little angry at this point
Thanks for any info!
BRay09
05-29-2011 10:10 AM
