Map line?
Old Jan 17, 2012 | 05:31 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Map line?
Where is the map line? How do i clean it? And after i drain the fuel bowl, do i have to refill it manually or does the pump fill it up?
Old Jan 17, 2012 | 05:34 PM
fordpride's Avatar
fordpride
Map line is hooked to the pass. side intake plenum and runs to the map pull it off and blow trough it. Refill the fuel bowl
Old Jan 17, 2012 | 05:48 PM
tshrager's Avatar
tshrager
I didn't even bother cleaning my MAP line, just replaced it
Old Jan 17, 2012 | 06:08 PM
Ford4Life7.3
I went mudding the other day, cleaned the motor on saturday and replaced air filter. This afternoon, i went to start it and it took me 3 tries to get it to run. Was on a high idle and was ROLLING black smoke when i revved it. Lots of white smoke at first. Got on the road and took it through the gears - had little power when i got on it, the rpms didnt raise much if i floored it, just slowly went up. It seemed to get better as i drove. I dropped it off at the stereo place to do some wiring, ill check the filter and map line when i get it back tonight
Old Jan 17, 2012 | 06:43 PM
Hussler's Avatar
Hussler
This is your MAP sensor and hose, although it would not cause the symptoms you described ...
Probably got water somewhere cleaning the engine - sensor and it's slowly evaporating, at least hope so.
Old Jan 17, 2012 | 06:56 PM
Ford4Life7.3
Thats what im hoping for. Im trying to think of things that would cause it...any ideas?
fordpride's Avatar
fordpride
Mine did that when I got water in the icp
Old Jan 17, 2012 | 06:57 PM
Ford4Life7.3
Did it evaporate or did you have to get a new one?
Old Jan 17, 2012 | 07:00 PM
fordpride's Avatar
fordpride
No it just had water in the plug I blew it out aand was good to go. Everytime I was my engine I blow all plug out with a air compressor
Old Jan 17, 2012 | 07:04 PM
Ford4Life7.3
Ill do that when i get it back, thanks Mike
Old Jan 17, 2012 | 08:37 PM
Ford4Life7.3
Mike, i blew out just about every sensor except 2 - the IPR and plug on the passenger side of the fuel bowl that has a lot of wires (it is screwed on to the bowl)
Ive heard of the IPR orings - if i unplug the IPR will i need to replace them? And whats the other plug? Both are considerably dirty
Old Jan 17, 2012 | 08:53 PM
fordpride's Avatar
fordpride
You can unplug the IPR and not hurt anything now if you take the IPR out of the HPOP then you have to change orings.
The plug on the fuel bowl is on a slide clip. If you pull the whole pulg to the rear of the truck it will come off
Old Jan 18, 2012 | 03:09 PM
blageurt's Avatar
blageurt
A loose tin nut on the IPR can cause it to run funny...I would check the wiring to the IPR clip for Rub-out...
Old Jan 18, 2012 | 05:50 PM
jhobbs26's Avatar
jhobbs26
what symptoms would a cloged or having a hole in the map line cause?
I just bought my '97 and it seemed to run just fine other than a small fuel leak. While i was in there replacing all the o-rings and fuel pump i noticed the map line had a small hole in it. I replaced the line with regular 5/16" fuel line. The truck seems to run just as it did before. I would think it would loose a little boost having a hole in the map line?
Old Jan 18, 2012 | 07:15 PM
blageurt's Avatar
blageurt
First of all the engine should be under load to make proper boost just revving the engine in neutral means dick ....Do you have a boost guage installed or acess to a live data scanner ? Theoretically If it is clogged the sensor reading will cause PCM to use a default value so you will be wasting fuel...it should also set a code. If you have a hole in it you should hear a hiss unless your Up- pipes leak and you are not making max boost regardless.....Do you have sooot around your pipes / collector areas ?
rock15t
Jul 28, 2012 05:38 AM
897.3idi
Jan 9, 2012 03:39 PM
ctann
Oct 26, 2009 06:57 PM
